I'm currently working through Cogdell's Foundations of Electrical Circuits and came across problem 4.39 d) as shown below:
Earlier in the question I found the frequency-to-be-used as 43.3x10^3 rad/s. Now, in order to make the circuit appear purely resistive the reactive part needs to sum to 0. In part c) of the question the capacitance was being added in series, so I simply used wL-(1/wC)=0. For d) however, the capacitance is to be in parallel with the inductor, leading to the (seemingly) unsolvable equation:
The book says the answer is C=0.1uF, and that it should lead to a real impedance of 400ohms. The only approach to this question I haven't taken is using the formula for the impedance angle for an R(L||C) circuit, but I'm not actually sure what that formula is. Any insight or hints are appreciated! Thanks.
No, you should consider the capacitor in parallel to the input ports, like below:
Now it's easier to first find the input admittance and then put the imaginary parts equal to zero to find the right capacitance. Reverse the real part to get the real impedance.
    \$\begingroup\$ Ah, that makes sense! I recalculated the impedance expression for C||(R+L) instead of R+(L||C) and got the answer in the book. Funny how sometimes the hardest part of a question is just setting it up right :P Thanks for the help. \$\endgroup\$
    – Eric
    Aug 9, 2018 at 21:23
No it isn't because that leads to the whole impedance being infinity; a resistor in series with L||C at resonance --> infinity.
The capacitor is applied across the two terminals on the left and the composite impedance is therefore: -
$$\dfrac{R+j\omega L}{1-\omega^2LC +j\omega RC}$$
If you then take the complex conjugate of the denominator and multiply top and bottom of the equation, the denominator becomes purely real but the numerator is complex. Numerator: -
$$R-RLC\omega^2 -j\omega R^2C+j\omega L-j\omega^3L^2C+\omega^2RLC$$
And the solution needed is for when the imaginery parts are zero i.e.: -
$$=R^2C+L-\omega^2L^2C = 0$$
If you whittle this down a bit, you'll find that the frequency where the impedance is real is: -
$$\omega = \sqrt{\dfrac{1}{LC}-\dfrac{R^2}{L^2}}$$
You know what omega, R and L are so plug those into the formula above and rearrange to find C.
The easiest way is \$\omega_o=1/\sqrt{LC}\$ then solve for C for series.
Here the reactance of \$X_C\$ cancels \$X_L\$. \$Z=R-\dfrac{1}{\omega C}+\omega L =R+0\$
For shunt use the sum of admittance , Y.
\$Y=1/R|| (\dfrac{1}{\omega L}-\omega C)=1/R || 0=0\$ thus Z is infinite.
In both cases, the solution is the same easy 1st formula.
  • \$\begingroup\$ No this is wrong Tony. \$\endgroup\$
    Aug 9, 2018 at 20:23
  • \$\begingroup\$ Ok Andy. .. pls advise \$\endgroup\$ Aug 9, 2018 at 22:29
  • \$\begingroup\$ I think your assumption that the C is parallel to the L (like the OP assumes) is wrong. C is across the input terminals. \$\endgroup\$
    Aug 10, 2018 at 7:06
  • \$\begingroup\$ Oops my eyes must be getting worse \$\endgroup\$ Aug 10, 2018 at 11:18
