-2
I'm trying to use the following dimmer: https://www.smarthome.com/switchlinc-dimmer-insteon-2477dh-remote-control-dimmer-dual-band-high-wattage-white.html
with these lights
https://www.eledlights.com/led-lights/eled-indoor-lights/led-drop-ceiling-panel-lights.html
is there any product I can buy to fix the voltage issue and eliminate buzzing/flickering?
thanks!
closed as off-topic by Transistor, Dave Tweed Aug 9 '18 at 20:56
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Dave Tweed
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ ok so is there another stack exchange where I can post this question? \$\endgroup\$ – swinefeaster Aug 9 '18 at 21:29
  • \$\begingroup\$ Try Home Improvement StackExchange. However, someone may call you out for asking the same question on different SE websites. \$\endgroup\$ – KingDuken Aug 9 '18 at 21:45
  • \$\begingroup\$ If this were viewed as a design issue , one can load the Triac with diode bridge to R:CR filter voltage divider using about 5 Watt load to scale and low pass filter to peak voltage of 10V using 2RC=0.3 second product \$\endgroup\$ – Sunnyskyguy EE75 Aug 9 '18 at 22:00
  • \$\begingroup\$ it is not possible to use that dimmer with that light fixture. You need a 0-10V dimmer - which is a completely different thing to what you have. The dimmer you have controls the power delivered to the light, while a 0-10V dimmer supplies a control signal to the light. \$\endgroup\$ – brhans Aug 10 '18 at 13:52
From the manufacturer website.
0 -10V LED dimmer is required.
Recommendation: Lutron DVSTV
  • \$\begingroup\$ that's not a smart switch (does not work with wifi home automation) \$\endgroup\$ – swinefeaster Aug 9 '18 at 21:28
