Solved: if you search for "GP-2 PCB Board Umbrella Shape 5.3mm Tip Testing Probe Pins Receptacles" you will find these probes! Thanks for the help!
I am designing an electrical test fixture, and I have all the probes figured out for testing pads and soldered pins for terminals.
However, I am having a hard time finding any pogo pins that would partiall fit into a 0.155" mounting holes, to act as registration points and guide the device under test down onto all of the probing pins.
I know that at least one must exist, since I found it in this YouTube video.
Here is a picture of the giant registration or locator probe for the four mounting holes.
Can anyone suggest a proper name or part number or search term for this device?
It is not in the IDI (Smiths Connectors) or ECT Contact Products websites as far as I can tell, and the google searching results failed.
Thanks for any help!
