I just ran the DRC check in Altium for my PCB and I get errors on trace width for every trace segments on the board.
What is the reason for this ? It generated thousands of errors even tho all the traces are 4 to 5 mils wide.
All tracks width rules are set to >= 4 mils
This is the error message I get under "Rule Violations" :
Clearance Constraint (Gap=3.5mil) (All),(All)
Clearance Constraint: (Collision < 3.5mil) Between Track (52761.3mil,31343.2mil)(52769.499mil,31343.2mil) on Solder Side And Arc (52769.499mil,31340.4mil) on Solder Side
Edit: It also affects trace much much larger than 3.5 mils
  • \$\begingroup\$ What is the actual error message? \$\endgroup\$
    – Daniel
    Aug 10, 2018 at 21:32
  • \$\begingroup\$ Are those white rings vias? or some other thing you've placed on the corners? You wouldn't normally see rings like that at a bend in a track. \$\endgroup\$ Aug 10, 2018 at 21:34
  • \$\begingroup\$ @Daniel I added it to the question. and PeterBennett Nope, these are only routed, no vias, no nothing, pure corners \$\endgroup\$
    – GmodCake
    Aug 10, 2018 at 21:35
  • \$\begingroup\$ Well, the error message says the violation is between a track and an arc - so somehow arcs were placed where the tracks bend. \$\endgroup\$ Aug 10, 2018 at 21:37
  • \$\begingroup\$ Are the elements you're connecting on the same nets? (Are they connected to the same net name in your schematic?) \$\endgroup\$
    – Daniel
    Aug 10, 2018 at 21:38
It turns out it was in the clearance rule I selected "Any nets" by mistake which meant the rule was applied to any segment no matter what net it is from, changing it back to "Different nets only" fixed it.
The image you've attached is for Minimum Clearance between components. There should be another dialog that defines the minimum and maximum trace widths. Double check that they are correct.
  • \$\begingroup\$ It doesn't work not matter what I put, all my tolerance, clearance, trace width are >4 mils \$\endgroup\$
    – GmodCake
    Aug 12, 2018 at 6:29
What ARCs is it referring to? From your picture, I can't see any.
Use the PCB Filter "IsArc" to see where these mystery geometries are coming from.
Did you accidentally convert your vias to free pads? I could see that causing some issues for the DRC.
