I am working on audio preamp project in Altium. I have 8 analog inputs, connected to belonging relay using Altium's Multi Channel Design: Audio Inputs Now, when I compile this project and update PCB, I get tracks, which connect audio input and it's relay for only first input: Tracks problem Tracks should be there for every audio input, what did I wrong?
  • \$\begingroup\$ you didn't name the traces EXACTLY the same did you? you did do "Audio_input_left1, Audio...." \$\endgroup\$
    – user16222
    Aug 11, 2018 at 13:04
To make you schematic work as drawn you only need a small modification. Try this: enter image description here
  • \$\begingroup\$ This was hard one for me to crack, I am still newbie, it works now!!!!! \$\endgroup\$ Aug 15, 2018 at 1:26
  • \$\begingroup\$ Glad you got it working! \$\endgroup\$
    – Luke Gary
    Aug 15, 2018 at 18:31
I think you may have to define the connection between the two repeat sheet symbols as a bus instead of wire. Looking at the example in the Altium help file shows all repeat channels first have a bustap, with the name of the bus, than a bus with the same name and the '[1..8]' brackets.
example from altium
