Using LTSpice XVII. I want to import the Diodes Incorporated ZXTP19020DG model. The SPICE model from their web site is:
*DIODES_INC_SPICE_MODEL ZXTP19020DG
*SIMULATOR=SIMETRIX
*ORIGIN=DZSL_DPG
*DATE=7/01/2013
*VERSION=1
.MODEL ZXTP19020DG PNP IS=8.5E-13 NF=1 BF=530 VAF=25.8 ISE=1.2E-13
+ IKF=3.8 NE=1.48 BR=130 VAR=5.15 ISC=0.8E-13 NC=1.23 RC=0.0045 RB=0.15
+ RE=0.009 QUASIMOD=1 RCO=0.27 GAMMA=2E-10 CJC=112E-12 MJC=0.4 VJC=0.6
+ CJE=345E-12 MJE=0.53 VJE=0.95 TF=0.59E-9 TR=4.2E-9 TRC1=.003 TRB1=.003
+ TRE1=.003 XTB=1.4
I copy-n-paste the .MODEL stanza into the standard.bjt file. I then open LTSpice and create a new schematic. I add a PNP transistor, right-click to Pick New Transistor, but the ZXTP19020DG does not show up on the list.
It may seem like I need to tell LTSpice to reload the components — if I erase the 2N2222 and 2N2907 (the first two entries in the original standard.bjt file), the 2N2907 still shows up on the Pick New Transistor dialog (for a PNP transistor). In all cases, I close and re-open LTSpice after any changes to standard.bjt. I also checked that there is only one standard.bjt file on the whole C: drive (under C:\Program Files\LTC\LTspiceXVII\lib\cmp).
This is what the beginning of the standard.bjt file looks like (I also added the NPN version, ZXTN19020DG, just in case):
* Copyright © 2000 Linear Technology Corporation.   All rights reserved.
.model ZXTN19020DG NPN IS=9E-13 NF=1 BF=530 IKF=6 VAF=105 ISE=8E-14
+ NE=1.4 NR=1  BR=174 IKR=1 VAR=12.8 ISC=4E-13 NC=1.37 RB=0.17 RE=0.0055
+ RC=0.0035 CJC=89E-12 MJC=0.34 VJC=0.51 CJE=365E-12 MJE=0.39 VJE=0.8
+ TF=9E-10 TR=0.55E-8 XTB=1.4 TRC1=.005 TRB1=.005 TRE1=.005 QUASIMOD=1
+ RCO=0.15 GAMMA=0.3E-9
.model ZXTP19020DG PNP IS=8.5E-13 NF=1 BF=530 VAF=25.8 ISE=1.2E-13
+ TRE1=.003 XTB=1.4
.model 2N2222 NPN(IS=1E-14 VAF=100
+   BF=200 IKF=0.3 XTB=1.5 BR=3
+   CJC=8E-12 CJE=25E-12 TR=100E-9 TF=400E-12
+   ITF=1 VTF=2 XTF=3 RB=10 RC=.3 RE=.2 Vceo=30 Icrating=800m  mfg=NXP)
.model 2N2907 PNP(IS=1E-14 VAF=120
+   BF=250 IKF=0.3 XTB=1.5 BR=3
+   CJC=8E-12 CJE=30E-12 TR=100E-9 TF=400E-12
+   ITF=1 VTF=2 XTF=3 RB=10 RC=.3 RE=.2 Vceo=40 Icrating=600m mfg=NXP)
etc.
What am I missing or doing wrong?
    \$\begingroup\$ Add a parenthesis after PNP or NPN .model ZXTN19020DG NPN (IS=9E-13 NF=1 BF=530 IKF=6 VAF=105 ISE=8E-14 + NE=1.4 NR=1 BR=174 IKR=1 VAR=12.8 ISC=4E-13 NC=1.37 RB=0.17 RE=0.0055 + RC=0.0035 CJC=89E-12 MJC=0.34 VJC=0.51 CJE=365E-12 MJE=0.39 VJE=0.8 + TF=9E-10 TR=0.55E-8 XTB=1.4 TRC1=.005 TRB1=.005 TRE1=.005 QUASIMOD=1 + RCO=0.15 GAMMA=0.3E-9) This work for me. \$\endgroup\$
    – G36
    Aug 11, 2018 at 16:56
  • \$\begingroup\$ Didn't work. I first added it without space between the NPN/PNP and the parenthesis as in the other entries in the file, then added a space as in your comment. Neither one works. I also noticed that the list has columns for manufacturer, Vceo, and Ic --- so, I added made-up values of Vceo and Icrating as well as a mfg parameter at the end; still doesn't not work. \$\endgroup\$
    – Cal-linux
    Aug 11, 2018 at 17:33
  • \$\begingroup\$ An "extra-fishy" detail: I edit the standard.bjt file and remove the entries 2N2222, 2N2907, 2N3904, and 2N3906. Save the file, close LTSpice, re-launch LTSpice, add a PNP transistor, right-click on it, and the "Pick New Transistor" dialog does show 2N2907 and 2N3906. Any ideas on what's going on? \$\endgroup\$
    – Cal-linux
    Aug 11, 2018 at 17:38
    \$\begingroup\$ electronics.stackexchange.com/questions/351035/… \$\endgroup\$
    – G36
    Aug 11, 2018 at 17:46
  • \$\begingroup\$ @G36 -- BINGO! The file was the one under "My Documents" :-\ Turns out that on Wine, the "My Documents" folder is a symbolic link to the Unix user's home directory, but the search function in the file browser does not follow symlinks; that's why I searched for standard.bjt under the C: drive and it only showed one, the one under c:\Program Files ... Oh well, mystery solved, it is working now! \$\endgroup\$
    – Cal-linux
    Aug 11, 2018 at 17:59
I don't think you can add a + to indicate a line extension, its 1 line per model. It should look like the others. Here is an example:
.model RFNL5BM6S D(Is=778.9p N=1.419 Rs=25.53m Ikf=81.74m Eg=1.05 Cjo=93p M=513.2m Vj=714.8m Isr=358.2p Nr=3 Bv=600 tt=88.29n Tikf=18m Trs1=700u Iave=5 Vpk=600 mfg=Rohm type=FastRecovery)
Second thing, check your directory. The new LT spice places a folder in
 User\Documents\LTspiceXVII\lib\cmp\standard.dio
this is the one that needs to be edited.
