I am interested in testing some low voltage cables for their quality. For example, USB, audio and Ethernet cables.
Testing continuity is simple, but I want to know if these cables may momentarily disconnect when stressed, such as when bent.
The ideal indicator would be like the buzzer from my multimeter which I can hear a sound with continuity only that I want to hear a sound when there is an open circuit. Is it something that I can add to my multimeter to test for short period of open circuit? It would be even better if I can use it to test headphone cable (without having to cut the cable, of course).
  • \$\begingroup\$ The Behringer cable tester CT100 does exactly that. Is three wires at the time enough for you? \$\endgroup\$ – winny Aug 14 '18 at 7:01
  • \$\begingroup\$ Sure, something can be designed as an add-on to your multimeter. It would be simpler to make a dedicated tester though, no real need to get the multimeter involved. No need to design one either, see winny's comment: it exist already. And it is even affordable. \$\endgroup\$ – Bimpelrekkie Aug 14 '18 at 7:17
    \$\begingroup\$ If you stress a cable which is intended for high frequency signals like an Ethernet cable, it may physically still pass a DC current but not be able to pass the signal it is designed for. \$\endgroup\$ – Oldfart Aug 14 '18 at 7:21
  • \$\begingroup\$ Good point. Fortunately, I also have a managed Ethernet switch that can also test for signal quality. \$\endgroup\$ – some user Aug 14 '18 at 15:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
