I've soldered the AT90USB1286 Chip on a PCB like on this circuit: Imgur
Schematic
If I measure the pins, caps, resistors etc. with a multimeter, everything seems to be powered and fine. Reset button pulls to ground. And yet, the computer doesn't recognize any USB device when I plug the USB cable in.
I've tried it on Mac and a Linux PC. lsusb doesn't show anything new after plugging in. Same goes for Mac.
Does anyone have an idea how to troubleshoot this? How to get this chip recognized over USB? Thanks a lot.
    \$\begingroup\$ How is the reset pin? High or Low? According to datasheet the reset Pin is low active \$\endgroup\$ Commented Aug 14, 2018 at 7:59
    \$\begingroup\$ Why is Vbus disconnected? \$\endgroup\$ Commented Aug 14, 2018 at 8:21
  • \$\begingroup\$ Is a clean blank chip? Who do you expect to control the USB peripheral, you need to load a bootloader or something like that using a programmer first. \$\endgroup\$
    – Dorian
    Commented Aug 14, 2018 at 8:27
  • \$\begingroup\$ @Dorian Thought the same, however by the datasheet, it seems like the chips come preprogrammed with an USB bootloader. \$\endgroup\$ Commented Aug 14, 2018 at 8:30
    \$\begingroup\$ Thanks for the quick responses! Yes the xtal is 16 Mhz. It is a clean chip, but I also thought that a bootloader is preinstalled, after reading the datasheet. And the Reset pin is High by default. When pressing the switch, it is pulled to ground (low). I've measured this by multimeter, it works. 5V high, 0V low... \$\endgroup\$ Commented Aug 14, 2018 at 8:45
Leaving the Vbus pin floating seems a bit strange.
The datasheet shows this configuration: enter image description here
None of the configurations shown in the datasheet leaves the Vbus pin floating. Just try connecting it up and see if that helps anything.
    \$\begingroup\$ That would be the problem - "The USB peripheral cannot attach to the bus while VBUS bit is not set." - if VBUS is low (likely if it is floating), the USB peripheral won't connect. \$\endgroup\$ Commented Aug 14, 2018 at 8:39
  • \$\begingroup\$ Thanks for the hint! It is not really floating, all VCC connections are connected to each other. I've built the board after this manual: github.com/ruiqimao/keyboard-pcb-guide And power seems to be everywhere it should...that wouldn't be the case if this was floating, right? \$\endgroup\$ Commented Aug 14, 2018 at 8:52
  • \$\begingroup\$ @MigBugmajor The issue isn't about VCC pins, those are fine. The VBUS pin is the issue, I suspect. (Which, the tutorial shows as connected to VCC. You, on the other hand, have it floating. It's the pin 8 on the schematic you have provided) \$\endgroup\$ Commented Aug 14, 2018 at 9:04
  • \$\begingroup\$ Oooooh now I see it! Holy crap. That has to be it. Thanks so much for the help. I will connect it tonight and report if it worked \$\endgroup\$ Commented Aug 14, 2018 at 9:11
