I'm trying to write a library for my hobbyish purpose and it's almost ready for a smoke test. The only thing that annoys me is a called-once fuction :
(Note: all uppercase phrases are macro constants)
/////////// Interface clock enable
LCD_CTRL_PORT_CLK_EN;
LCD_DATA_PORT_CLK_EN;
//////////// Config control pins
//// pull up
LCD_CTRL_PORT->PUPDR &= ~LCD_CTRL_PORT_32BIT_MASK;
LCD_CTRL_PORT->PUPDR |= ( (0b01 << (LCD_CS_POS*2U))
                        | (0b01 << (LCD_RS_POS*2U))
                        | (0b01 << (LCD_WR_POS*2U))
                        | (0b01 << (LCD_RD_POS*2U))
                        | (0b01 << (LCD_RST_POS*2U)) );
//// set output direction
LCD_CTRL_PORT->MODER &= ~LCD_CTRL_PORT_32BIT_MASK;
LCD_CTRL_PORT->MODER |= ( (0b01 << (LCD_CS_POS*2U))
//// Max output speed
LCD_CTRL_PORT->OSPEEDR &= ~LCD_CTRL_PORT_32BIT_MASK;
LCD_CTRL_PORT->OSPEEDR |= ( (0b11 << (LCD_CS_POS*2U))
                            | (0b11 << (LCD_RS_POS*2U))
                            | (0b11 << (LCD_WR_POS*2U))
                            | (0b11 << (LCD_RD_POS*2U))
                            | (0b11 << (LCD_RST_POS*2U)) );
//// all control pin set HIGH (idle)
LCD_CTRL_PORT->BSRR |= (LCD_CS | LCD_RS | LCD_WR | LCD_RD | LCD_RST);
//////////// Config data pins
LCD_DATA_PORT->PUPDR &= ~LCD_CTRL_PORT_32BIT_MASK;
LCD_DATA_PORT->OSPEEDR &= ~LCD_DATA_PORT_32BIT_MASK;
LCD_DATA_PORT->MODER &= ~LCD_CTRL_PORT_32BIT_MASK;
#if LCD_USE8BIT_MODE == 1
LCD_DATA_PORT->PUPDR |= ( 0x5555 << (LCD_DATAPORT_OUTPUT_OFFSET*2U) );
LCD_DATA_PORT->OSPEEDR |= ( 0xFFFF << (LCD_DATAPORT_OUTPUT_OFFSET*2U) );
LCD_DATA_PORT->MODER |= ( 0x5555 << (LCD_DATAPORT_OUTPUT_OFFSET*2U) );
LCD_DATA_PORT->BSRR = ( 0xFF << (LCD_DATAPORT_OUTPUT_OFFSET*2U) );
#else
LCD_DATA_PORT->PUPDR |= 0x55555555;
LCD_DATA_PORT->OSPEEDR |= 0xFFFFFFFF;
LCD_DATA_PORT->MODER |= 0x55555555;
LCD_DATA_PORT->BSRR = 0xFFFF;
#endif
I'm using True Studio and the platform is STM32F3. The function just plainly modifies some registers with constants derived from some macro constants.
But why it does cost almost 1 kB of flash (in .text section, I'm using Truestudio's build analyzer) although it isn't quite long ? Even HAL-GPIO function is 3x smaller.
Example macro:
#define LCD_XXXX_PORT  GPIOX
#define LCD_XXX        GPIO_PIN_X
#define LCD_XXX_POS    POSITION_VAL(LCD_XXX)
  • \$\begingroup\$ Have you compiled with the optimiser turned on? It often makes a huge difference, and I would expect something like the above to collapse to an inline function or the like at -o2. \$\endgroup\$
    – Dan Mills
    Aug 14, 2018 at 15:59
    \$\begingroup\$ "it cost almost 1 kB of flash" I don't think the code shown is that big. Check in the final result where the 1K comes from. The linker might pull in a big blob of library code. \$\endgroup\$
    – Oldfart
    Aug 14, 2018 at 16:02
    \$\begingroup\$ What are LCD_CTRL_PORT_CLK_EN and LCD_DATA_PORT_CLK_EN doing? You should really post the assembly you get, at least the first few dozen lines. \$\endgroup\$
    – Adam Haun
    Aug 14, 2018 at 16:47
    \$\begingroup\$ Most of this should be collapsing to constants at compile time. You need to examine your output to see where the size is really being taken, likely it isn't here. Also don't forget there's some fixed overhead like the vector table. \$\endgroup\$ Aug 14, 2018 at 17:57
    \$\begingroup\$ I was referring to using the keyword 'register' in the variable definition to ask the compiler to assign and keep the pointer in a processor local register. Like: register int *LCD_CTRL_PORT; (But then replace int with the real type of the LCD control port typedef) \$\endgroup\$
    – Oldfart
    Aug 15, 2018 at 20:05
I think I have found two reasons:
1. The compiler isn't smart enough to recognize some compile time constants
The problem lies in these macros: #define LCD_XXX_POS POSITION_VAL(LCD_XXX)
I want to create an automatic mask for various GPIO configuration register. In order to do so, I must at least know the position of each pin. So I use POSITION_VAL(), a macro function provided in ST's CMSIS header :
#define POSITION_VAL(VAL)     (__CLZ(__RBIT(VAL)))
Basically, the macro function takes an parameter (in this case, single-GPIO-pin mask), flips it with rbit instruction, calculates leading zeros with clz instruction and returns leading zeros. By doing so, I can get the position of LCD_XXX pin quite easily.
The compiler seems to replace the macro function with it body everytime, instead of replacing them with constants. I have tested by defining LCD_XXX_POS as constants, the function size reduced to ~380 bytes.
2. Something was wrong with project setting
About the macro POSITION_VAL(VAL), the compiler may not (do not ?) care if it's fed with constants. So, as suggested by this article, I created a new header :
#ifdef POSITION_VAL
#undef POSITION_VAL
#endif
#ifdef __GNUC__
# define POSITION_VAL(VAL) (__builtin_ctz(VAL))
#else
# define POSITION_VAL(VAL) (__CLZ(__RBIT(VAL)))
#endif
GNU C has __builtin_ctz which accomplishes the same thing but can deduce the value at compile time if appropriate.
But Truestudio highlighted #ifdef __GNUC__ branch as inactive although I was sure that I was using GCC. I tried with a new project template, #ifdef __GNUC__ branch wasn't marked inactive and the function only cost ~180 bytes.
Clearly, there was something wrong.....
    \$\begingroup\$ A compiler would have to be pretty clever if it should know at compile time how to replace a set of custom inline assembly. It would require a complete simulator. That is a pretty silly and "surprising" macro which should have been written as an inlinable function. \$\endgroup\$
    – pipe
    Aug 16, 2018 at 7:41
But why it does cost almost 1 kB of flash although it isn't quite long ? Even HAL-GPIO function is 3x smaller.
Let's first see what you did ask for.
9 |= operations with a literal*
6 &= ~operation with a literal*
1 = operation with literal*
*assuming the compiler optimizes arithmetic on constants on -O1
The |= takes 4 instructions (2 LDR, ORR and STR), and two constants. (18 bytes)
The &=~ is similar to |=, since ~const will be optimized.
An = is three instructions (LDR,MOV and STR), and two constants. (10 bytes)
Since registers are volatile, these assignments will no be optimized further. This means the code above is about 280 bytes. Maybe less, on if more than -O1 by keeping some pointers around in r1.
However, an empty ARM project is about 600 bytes as well.
That is just the vector table (~80 words), and the stack and memory zero initialization.
1kB, for "just gpio" is not big.
  • \$\begingroup\$ Thanks for disassembly. It will cost some times for me to understand them :) \$\endgroup\$
    – Long Pham
    Aug 16, 2018 at 14:46
  • \$\begingroup\$ I have noobly managed to squeeze it down to 176 B. \$\endgroup\$
    – Long Pham
    Aug 16, 2018 at 14:47
    \$\begingroup\$ @LongPham Hint: You can quickly have test dissasembler in keil simulator. \$\endgroup\$
    – Jeroen3
    Aug 17, 2018 at 5:36
It could be because you are using STM32F3 peripheral library. If you only need GPIO access you can include stm32f3xx.h directly. Remove USE_STDPERIPH_DRIVER from build config.
    \$\begingroup\$ With proper linker flags, unused code is removed at the link stage. \$\endgroup\$ Aug 14, 2018 at 17:56
  • \$\begingroup\$ USE_STDPERIPH_DRIVER, it does not appear in build config since I'm using STM32Cubemx. \$\endgroup\$
    – Long Pham
    Aug 15, 2018 at 18:07
