I am trying to read the status register for the EEPROM following the instructions in this Application Note. I wanted to have the opinion of the community on the signals I am getting. They don't seem normal to me.
http://ww1.microchip.com/downloads/en/AppNotes/01073A.pdf
Wiring Diagram: I am using the exact same pinout recommended in the Application Note.
When I read MISO, I get a strange behavior. Output of the EEPROM
MOSI and CS Signals:
I get the MOSI signal as expected on rising edge. Input to the EEPROM
Chip Select sync with Clock
I setup the clock to tick @1MHz
SPI Initialization code, and running code in my main.c. (from eewiki, adapted to my needs)
#define eepromCS LATBbits.LATB15
void initSPI(void)
// Add GPIO config on pin RB15
eepromCS = 1; //GND
IEC0bits.SPI1EIE = 0;
IEC0bits.SPI1RXIE = 0;
IEC0bits.SPI1TXIE = 0;
SPI2CONbits.ON = 0;
SPI2BUF = 0;
SPI2BRG = 0; // 1MHZ
SPI2STATbits.SPIROV = 0;
/* SPI2CON Settings */
SPI2CONbits.FRMEN = 0;
SPI2CONbits.SIDL = 0;
SPI2CONbits.DISSDO = 0;
// 8 bits !
SPI2CONbits.MODE16 = 0;
SPI2CONbits.MODE32 = 0;
SPI2CONbits.CKP = 0; // Active state is high
SPI2CONbits.CKE = 0; // sampling from idle to active
SPI2CONbits.SSEN = 0;
SPI2CONbits.MSTEN = 1;
SPI2CONbits.SMP = 0; // sample during transmission
SPI2CONbits.ON = 1;
int main(void)
TRISBbits.TRISB15 = 0;
CSEEPROM = 1;
initSPI(); //EEPROM as a slave
unsigned char status;
unsigned char tmp;
//First READ
while (!SPI2STATbits.SPITBE);
eepromCS = 0;
SPI2BUF = 0x05;
while (!SPI2STATbits.SPIRBF);
status = SPI2BUF;
SPI2BUF = 0;
status = SPI2BUF;
eepromCS = 1;
write_char(status);
//Enable write LATCH
eepromCS = 0;
SPI2BUF = 0x06;
tmp = SPI2BUF;
eepromCS = 1;
//Read Status register
eepromCS = 0;
SPI2BUF = 0x05;
status = SPI2BUF;
SPI2BUF = 0;
status = SPI2BUF;
eepromCS = 1;
//write_char(status);
while (42);
return 0;
I did screenshots only for the last two operations (write latch enable, and read from status register). I have exactly the same signals when I read the status register before I send the write latch command.
I am using PIC32MX Olimex prototyping board, Below the protoboard documentation and EEPROM datasheet.
https://www.olimex.com/Products/PIC/Proto/PIC-32MX/resources/PIC-32MX.pdf http://ww1.microchip.com/downloads/en/DeviceDoc/22064B.pdf
As usual the devil is in the details, it would be great if I could have a new look on my issue. Maybe I missed something.
Thank you for your help !
PS: increasing the baud to match 20MHz makes the signal flat but doesn't solve my issue.
It doesn't look like anything code-related. It looks like either a pin shorted to another output pin which is set to zero ( or another slave not tri-stating its MISO ). Disconnect the memory chip, set PIC MISO to output and try to toggle it by writing 1 and 0 to the corresponding port bit.
Another suspect is power supply to the memory chip. Make sure it receives VCC and has a capacitor from VCC to ground.
  • \$\begingroup\$ Thank you for your answer. I did try your solutions, and it doesn't work. I did some tests with the multimeter and I discovered something horrifying. Current doesn't flow into the EEPROM. I actually have 2, I hope I didn't short circuited them both. I have a generator with 5V and I am testing current with a multimeter. It stays @ 0 microA Any clue as to how I could debug it ? I tried other circuits too, and I am getting the same result \$\endgroup\$ Aug 16, 2018 at 18:05
  • \$\begingroup\$ If the chip is not damaged, you won't be able to see current into this chip with a multimeter. Did you try to toggle MISO as suggested? \$\endgroup\$ Aug 16, 2018 at 21:55
  • \$\begingroup\$ I tried to enable RG7 as suggested and I get the right ouput line. I even tried to change the prototyping board, and nothing happens. It must be something small. I have to start everything from the beginning \$\endgroup\$ Aug 17, 2018 at 14:24
  • \$\begingroup\$ I would like to point out that I was trying to get the operating current in the multimeter, I don't understand why I would not be able to see current ? In the datasheet it says that in Standby mode, I would get between 12 and 20 microA imgur.com/a/bu4lNd8 – \$\endgroup\$ Aug 17, 2018 at 21:35
