I have this USB voltage tester that I place between my usb wall charger and a USB charging cable. This device gives me the total current that went through over a period of time. Let's say after 2.5h of charging I get this:
IN: 5.22V TIME: 150min 0.835A
And that means over the duration of two hours and a half 835mA passed through at roughly 5V (that somewhat varies a bit)
The thing is, the device I am charging has a 3.7V battery with a total capacity of 800 mA. And this is where it all gets confusing to me:
The total power that went through should be ~5 x 0.835 = 4.174W
However, the 3.7V battery can take 3.7 x 0.8 = 2.96W = ~3W
That's over 1 Watt difference that I don't know where it went. The charging takes place by plugging a miniUSB cable directly in the device that holds the battery. The device has a display that briefly gets lit the first 15 minutes but then I managed to shut it down and remains black throughout the charging. There is also one red LED that stays on throughout the charging duration and then turns off.
Should I believe over a quarter (over 1W) of the power passed through is waste? Or is my math wrong?
Edit: full charging video available here https://www.youtube.com/watch?v=5kYaG2KwxDw
Learn this: Energy = Power x Time.
No, that's the average current, not the total. To try and "total" a current would be like trying to total your speed on a 150 minute journey. It makes no sense.
And that means over the duration of two hours and a half 835 mAh passed through at roughly 5V (that somewhat varies a bit).
No. The mAh is calculated, as suggested by the units, by mA x time (in hours). 835mA for 2.5 hours gives 2088mAh.
The device I am charging has a 3.7V battery with a total capacity of 800 mAh. And this is where it all gets confusing to me:
No, you want to calculate the total energy that went in. That's power by time, so \$ E = VIt = 5 \times 0.835 \times 2.5 = 10.4 \text {Wh} \$
However, the 3.7V battery can take 3.7 x 0.8 = 2.96W = ~3W.
Again, W is power, Wh is energy. The battery can store 3 Wh during charge.
No, it's 1 Wh difference.
That seems reasonable. Your battery will get warm during charging and the missing energy will have been give off as heat.
  • \$\begingroup\$ Hey there! Thanks for your answer. I believe I may have not described correctly the device that I used to measure with. I updated my question with the video showing exactly how my numbers were produced, hopefully that will clear things a bit. \$\endgroup\$ Aug 18 '18 at 14:12
  • \$\begingroup\$ I didn't have any problems with your readings - only your units of measure. Have I helped at all? \$\endgroup\$
    – Transistor
    Aug 18 '18 at 15:14
  • \$\begingroup\$ I do not understand why would you multiply 835 mA with 2.5 when I specifically mentioned that the 835 mA were gradually registered by the device during those 2.5h and the video I added shows the same thing. Or, let me say this. The device registered an average of 334mAh for 2.5h. \$\endgroup\$ Aug 18 '18 at 15:46
  • \$\begingroup\$ Because you had confused your units in the question (and I had answered before you posted the video). You have called it both 0.835 A and 835 mAh. One is current and the other is current x time. \$\endgroup\$
    – Transistor
    Aug 18 '18 at 15:56
  • \$\begingroup\$ Thank you for the correction. Considering there was no considerable heating of the battery (I never noticed it to heat during several charges), do you still believe over 1 Watt out of 4 Watts got wasted through Joules effect? That is the thing that bugs me. \$\endgroup\$ Aug 18 '18 at 16:03
