I was testing the MOSFET driver LTC7004 and tried to supply power to VCC and GND from an Arduino Mega with a PWM signal. The schematic resembles a Bootstrap circuit. I connected an LED between pins connected to Gate and Source but the LED doesn't blink.
Can I really drive an LED with a MOSFET driver?
PS: We cannot :)
  • \$\begingroup\$ How is TS connected? It's very likely that the driver either isn't driving it because it detects some sort of fault, or because it's already damaged the LED from overvoltage. If you have access to a multimeter it may be helpful here. \$\endgroup\$
    – nanofarad
    Aug 19 '18 at 3:39
  • \$\begingroup\$ Show your schematic, please. What is the VCC leve? \$\endgroup\$ Aug 19 '18 at 3:41
  • \$\begingroup\$ I've updated the question with the schematic! \$\endgroup\$
    – Padmal
    Aug 19 '18 at 3:50
  • \$\begingroup\$ So, what are you expecting to see out of your LED? Are you expecting to see 10Hz 50% duty cycle or some such? By the way, why do you want to drive an LED in that fashion? \$\endgroup\$ Aug 19 '18 at 4:45
    \$\begingroup\$ @Blogger, you don't seem to have the grasp of how bootstrap gate drive circuits work. Read this, please. \$\endgroup\$ Aug 19 '18 at 5:54
