I use stm32_smart v2 development board and try make a cheap and reliable 7 bit input interface using 7 jumpers from GPIO to the ground. Internal pull up resistors are used. The first time I did not connect any GPIO to the ground and had 3.3V on them.
After the first connection I have from 1V to 2.7V on used GPIO, even when they are not connected to the ground any more. I have no idea what is going on, but it felt like I burned something.
I'm uploading all the code even unused functions, to make sure all I provide all the info.
#include "stm32f10x.h"
//#include "stm32_eval.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_usart.h"
#include "stm32f10x_exti.h"
#include "stm32f10x_tim.h"
#include "stdio.h"
//#include "tm1637.h"
#include "misc.h" /* High level functions for NVIC and SysTick (add-on to CMSIS functions) */
#define TRUE 1
#define FALSE 0
#define NoONE 0
#define TEAM_A 1
#define TEAM_B 2
//Timer ISR sets this flag to communicate with the main program.
static __IO uint8_t TimerEventFlag;
static __IO uint8_t TimerTicks=0;
static __IO uint8_t ControlTeam=NoONE;
static __IO unsigned int TeamATime;
static __IO unsigned int TeamBTime;
static __IO unsigned int InitialTime=65;
unsigned int timeformat(unsigned int seconds){
unsigned int min=0;
unsigned int sec=0;
min=(seconds/60);
sec=seconds%60;
return min*100+sec;
void Configure_DIP(void){
GPIO_InitTypeDef GPIO_InitStruct;
/* Set pin as input */
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9|GPIO_Pin_8;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_InitStruct);
/* Configure pins to be interrupts */
void Configure_AButton(void) {
/* Set variables used */
EXTI_InitTypeDef EXTI_InitStruct;
NVIC_InitTypeDef NVIC_InitStruct;
/* Enable clock for GPIOA */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0;
/* Add IRQ vector to NVIC */
/* PA0 is connected to EXTI_Line0, which has EXTI0_IRQn vector */
NVIC_InitStruct.NVIC_IRQChannel = EXTI0_IRQn;
/* Set priority */
NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0x00;
/* Set sub priority */
NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0x00;
/* Enable interrupt */
NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
/* Add to NVIC */
NVIC_Init(&NVIC_InitStruct);
/* Tell system that you will use PA0 for EXTI_Line0 */
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource0);
/* PA0 is connected to EXTI_Line0 */
EXTI_InitStruct.EXTI_Line = EXTI_Line0;
EXTI_InitStruct.EXTI_LineCmd = ENABLE;
/* Interrupt mode */
EXTI_InitStruct.EXTI_Mode = EXTI_Mode_Interrupt;
/* Triggers on rising and falling edge */
EXTI_InitStruct.EXTI_Trigger = EXTI_Trigger_Falling;
/* Add to EXTI */
EXTI_Init(&EXTI_InitStruct);
void Configure_BButton(void) {
/* Enable clock for GPIOC */
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
NVIC_InitStruct.NVIC_IRQChannel = EXTI9_5_IRQn;
GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource5);
EXTI_InitStruct.EXTI_Line = EXTI_Line5;
int main(void)
//Holds the structure for the GPIO pin initialization:
GPIO_InitTypeDef GPIO_InitStructure;
uint16_t bitwise_time=0; //for value from the DIP switches.
uint16_t portA_vals;
uint16_t portB_vals;
uint16_t iden16=1;
//Configure_AButton();
//Configure_BButton();
Configure_DIP();
//init game settings
portA_vals=~GPIO_ReadInputData(GPIOA);
portB_vals=~GPIO_ReadInputData(GPIOB);
//bit operations
if(portA_vals&iden16<<10){
bitwise_time=bitwise_time|1<<0;}
if(portA_vals&iden16<<9){
bitwise_time=bitwise_time|1<<1;}
if(portA_vals&iden16<<8){
bitwise_time=bitwise_time|1<<2;}
if(portB_vals&iden16<<15){
bitwise_time=bitwise_time|1<<3;}
if(portB_vals&iden16<<14){
bitwise_time=bitwise_time|1<<4;}
if(portB_vals&iden16<<13){
bitwise_time=bitwise_time|1<<5;}
if(portB_vals&iden16<<12){
bitwise_time=bitwise_time|1<<6;}
//set that as teams times
if(bitwise_time==0){
InitialTime=30;
}else if(bitwise_time==127){
InitialTime=99*60;
}else{
InitialTime=bitwise_time*60;
TeamATime=InitialTime;
TeamBTime=InitialTime;
// Configure SysTick Timer
/*System timer tick is used to measure time.
The Cortex-M3 core used in the STM32 processors has a dedicated timer
for this function. Its frequency is set as a fraction of the constant
SystemCoreClock (defined in file system_stm32f10x.c in the
STM32F10x Standard Peripheral Library directory.)
We configure it for 1 msec interrupts*/
if (SysTick_Config(SystemCoreClock/10)) while (1); //If it does not work, stop here for debugging.
//loop
while (1) {
asm("nop"); //doing nothing. should put into some energy save mode
}//End while(1)
} //END main()
// Systic interrupt handler
//Every 100 msec, the timer triggers a call to the SysTick_Handler.
void SysTick_Handler (void){
TimerTicks++;
/* Set interrupt handlers */
/* Handle AButton interrupt */
void EXTI0_IRQHandler(void) {
/* Make sure that interrupt flag is set */
if (EXTI_GetITStatus(EXTI_Line0) != RESET) {
/* Do your stuff when PA0 is changed */
ControlTeam=TEAM_A;
/* Clear interrupt flag */
EXTI_ClearITPendingBit(EXTI_Line0);
/* Handle BButton interrupt */
void EXTI9_5_IRQHandler(void) {
if (EXTI_GetITStatus(EXTI_Line5) != RESET) {
asm("nop");
if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_5)==0){
ControlTeam=TEAM_B;
EXTI_ClearITPendingBit(EXTI_Line5);
#ifdef USE_FULL_ASSERT
void assert_failed ( uint8_t* file, uint32_t line)
/* Infinite loop */
/* Use GDB to find out why we're here */
while (1);
#endif
