I apologize in advance, for only quickreading howtos, and, since I am only hobbyist, I actually don`t tinker with ac power generally.
Today I can`t bypass this : I need to connect 3 switching power supplies (1x 230V=>5V, 300W,60A; 1x 12V 20A; 1x 12V 15A) to a single cold device socket.
Question is : Is it safe to connect all three supplies in parallel to the cold-device-socket (whats the correct name in english for those !?) as long as I care for good wires (I have 1.5mm pure copper core cable with good pvc isolation, which should be a bit overdimensioned already) and propper soldering and isolation?!
Are there any hints that a professional electrician could give me ? (Apart from : dont touch ac power if you dont know what u are doing) .. I will be really really careful, I promise .. (soldered some cold-device-sockets to 3d-printers successfully already etc..)
Will the current evtl. be too much for the fuse thats built into the socket ?! I think in 230V AC all 3 together shouldn`t reach 10A !?
I`d love to read carefully and answer the question myself, but from my little knowledge, this should be possible and simple, I just want to be sure and I am already late with progress... thx in advance, Oliver
  • \$\begingroup\$ Like these ones? I'd call them IEC sockets. (well, Google mostly brings up plugs, not sockets) \$\endgroup\$
    – user253751
    Aug 20 '18 at 23:25
    \$\begingroup\$ Also soldering mains leads is probably far less dangerous than what you are thinking. It's just a cable, it's perfectly safe as long as it's unplugged. Just don't create a short circuit and then plug it in. \$\endgroup\$
    – user253751
    Aug 20 '18 at 23:25
  • \$\begingroup\$ yep, both of you are corrent, they are called IEC-sockets (thanks :) ). And everything went well fortunately, no short-circuit and everything is fine. \$\endgroup\$
    – Oliver
    Aug 23 '18 at 17:11
Calculate the currents on the mains side using \$ P = VI \$ but solving for \$ I = \frac {P}{V} \$. We'll assume they're all 100% efficient.
  • The 300 W unit gives \$ I = \frac {300}{230} = 1.3\ \text A \$.
  • 12 V, 20 A unit has \$ P = VI = 12 \times 20 = 240 \ \text W \$. \$ I = \frac {240}{230} = 1\ \text A \$ approx.
  • 12 V, 15 A unit has \$ P = VI = 12 \times 15 = 180 \ \text W \$. \$ I = \frac {180}{230} = 0.8\ \text A \$ approx.
Even if your power supplies are only 75% efficient (resulting in 33% extra current on the mains side) you will draw about 4 A. You are fine.
... to a single cold device socket. (Whats the correct name in English for those!?)
Mains socket? Wall socket? 230 V power socket?
Make sure you have a fuse on the supply.
    \$\begingroup\$ I dont know the correct english name for it. In german, its Kaltgerätebuchse. Thanks a bunch =) I just quickly added approximated values up and thought I was far away from 10A and as you calculated, this is correct fortunately. All power supplies have a fuse and the socket has a fuse too.. I am building up a case for 3d-printers controlled by raspberry.. \$\endgroup\$
    – Oliver
    Aug 20 '18 at 21:12
  • \$\begingroup\$ Danke. Google Translate gives "IEC socket"! \$\endgroup\$
    – Transistor
    Aug 20 '18 at 21:13
