When we talk about fiber-optic transmission, we almost always talk about copper to fiber-optic Ethernet conversion using fiber-optic transceivers.
But since fiber-optic communication is just transmission of any electrical signal in the form of light, I was wondering if there are other transceivers available for fiber-optic transmission, I mean for interfaces/protocols other than Ethernet.
In my search I could not come across any such transceivers. Whenever and wherever I see the word fiber-optic, it is related to Ethernet/networking only.
Any comments are appreciated.
closed as off-topic by Andy aka, brhans, laptop2d, Dmitry Grigoryev, Bimpelrekkie Aug 26 '18 at 10:24
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Have you like, googled, or read the fiber optic communcation wikipedia list which lists a bunch of different fiber optic standards? \$\endgroup\$ – PlasmaHH Aug 22 '18 at 11:12
    \$\begingroup\$ 'we almost always talk about copper to fiber-optic Ethernet conversion using fiber-optic transceivers.' I think the people working on backbone infrastructure have a thing or two to say about that claim. The reason you can't find any transceivers is because ethernet is the dominant infrastructure used for LAN. Other applications tend to either not be for computer networking (S/P DIF, Thunderbolt) or just not the kind of thing a consumer can buy (because they are meant for specific applications). \$\endgroup\$ – Joren Vaes Aug 22 '18 at 11:32
    \$\begingroup\$ If this is not a shopping question (off-topic) then it's unclear what you're really asking. Fiber-optic transceiver devices for 'low-level' use in any suitable communication link exist, so it's likely that you're looking in the wrong places and/or for the wrong things. \$\endgroup\$ – brhans Aug 22 '18 at 11:44
    \$\begingroup\$ 2105 hits here \$\endgroup\$ – brhans Aug 22 '18 at 12:27
    \$\begingroup\$ AFAIK, SFP transceivers aren't limited to Ethernet, since they don't actually interpret the data flowing through them in any way. (Very similar transceivers are used for Fibre Channel and Infiniband for example - I'm not sure if Ethernet, FC and IB ones are directly compatible, but if not it's probably just because the switch detects that it's the wrong transceiver, not because it can't work) \$\endgroup\$ – immibis Aug 23 '18 at 0:48
SONET is kind of popular in the telecomms world, very different to ethernet, and kind of cool in its way.
In reality many non ethernet uses exist, but we tend to try to use rates that are close enough to something used by either the phone company or the datacenter because economies of scale make optical modules for those line rates all kinds of cheap.
MADI for example (multichannel digital audio used in pro environments) often goes over 155Mb/s SFP modules marketed for SONET use by the telecom crowd, IIRC it actually runs the line at 125Mb/s, but close enough.
SDI digital video is another example, either at 1.55Gb/s, 3Gb/s or 12Gb/s, again SFP modules that are close enough usually exist.
Particularly with SFP interfaces they usually don't care about the protocol as long as DC balance is not too horrible and whatever you are sending can survive being highpassed at a few MHz (The ALC will stuff up the levels at the the slicer if you go slower then that). Apart from that, generate a PECL version of whatever you like and stuff it into a SFP+ socket, odds are it will work if you pick a reasonable module for the speed you need.
As already mentioned there are many possible communication transport layers possible over fiber optic links. Here is one useful application that uses a fiber optic link to extend a USB interface out to far beyond what is possible with standard USB cabling.
(Source Vendor Page)
This example shows a USB3.0 link of 50 feet but there are many product options in this space. If you search you can find USB2, HDMI, Ethernet, Audio etc.
There are many other link-layers transported on Fiber-optic medium, apart from Ethernet.
How about S/P DIF, Fiber Channel, Thunderbolt optical cables, to name a few ?
    \$\begingroup\$ 1. "Fibre Channel" is spelled with the British spelling of Fibre. 2. Many Fibre Channel rates are very close to Ethernet rates, and use similar encoding, so the transceivers for one will typically work for the other (but might be sold under different PNs due to test plan, etc) \$\endgroup\$ – The Photon Aug 22 '18 at 15:59
I am surprised no one mentioned good ol' TOSLINK. The simple board-mounted transmitters and receivers for it are available from digikey and the cables are cheap.
TOSLINK technology has evolved over the years. There are general purpose devices for up to 8Mbps and full-duplex SMI transceivers.
