I´m working on a proyect and i use OrCad/Spice to simulate the op amp that i gone use and my Voltage(output) signal is Constant and my Voltage(Input) is sinusoidal. enter image description here
    \$\begingroup\$ Your OpAmp's power supplies are connected upside down. You've put Vcc on V- and GND on V+. \$\endgroup\$ – brhans Aug 22 '18 at 13:06
    \$\begingroup\$ Hm, what is your question? \$\endgroup\$ – Marcus Müller Aug 22 '18 at 14:15
    \$\begingroup\$ Your professor should be giving you guys a bit more help before sending you here. \$\endgroup\$ – Spehro Pefhany Aug 22 '18 at 15:29
For the LM324 (and most 14 pin quad opamps), pin 4 is the positive supply and pin 11 the negative. Swap them round, then try again.
| improve this answer | |
