-1
I've searched and googled quite a bit on this subject, but haven't found any concrete answers. I understand that pulses are generated at the transmitter's end to get to the receiver's end.
More in specific, is it possible for the electrons to reach the other end of the wire if power is cut while current is already flowing?
And also, is it taken into account with this kind of propagation delay when establishing data transmission connections generally?
"I understand that pulses are generated at the transmitter's end to get to the receiver's end."
That is one of the ways we could transport information, there are other ways (which are usually more complex) as well.
"is it possible for the electrons to reach the other end of the wire if power is cut early from the source (a flow is already going through the wire)?"
I think in your view you see one (or a bunch of) electron(s) "carrying" the data to the other end. So to send something, an electron is pushed in by the transmitter and after a while it appears at the receiver.
That's not how it works! The conductor (wire) doing the actual transport is full with electrons. If I push in an electron then almost immediately (this change / wave travels at almost the speed of light) at the other end an electron will be pushed out. So the electron going in and the electron coming out are not the same one. And it does not have to be as they're all the same! So you would not be able to tell the difference anyway.
So if the wave is already travelling in the conductor and the connection to the transmitter is lost, the wave would still reach the receiver, no information is lost.
"is it taken into account with this kind of propagation delay when establishing data transmission connections generally?"
Yes, that is the electron(s) causing a wave in the conductor. This wave travels at about the speed of light. It is indeed an effect that needs to be considered for fast (high datarate) connections.
Example: take a look at a modern PC motherboard, more specifically the connections between the CPU and the RAM (memory). Note how some wires "wiggle" which seems pointless at that only makes them longer. But that's exactly the point, all wires need to be of the same length as we cannot have some bits arrive early and some later. All have to arrive at the same time so the traces need to be of equal length so all have the same propagation delay. There's an example in this question.
  • \$\begingroup\$ Ah, it makes more sense now! I never really knew that the pulse kept flowing even if the transmitter was lost. Thanks for simplifying! \$\endgroup\$ – poh Aug 23 '18 at 9:26
6
Electrons generally speaking do not travel through a wire. They do, very slowly, for DC current. So slow you could walk next to them, talk to your neighbor, and easily catch up. It's called the drift speed. It's mostly unimportant for electrical circuits. It can be important for static electricity and electrochemical processes.
What travels through a wire is a "shock front". Think cars in a traffic jam standing bumper to bumper. You push the last one, the first one, kilometers away, also moves. Almost instantly. For DC, that "shock front" is moved only one direction, for AC, the "cars" are moved back and forth.
    \$\begingroup\$ In a metallic conductor the drift speed is usually way under 1cm/s, it is that slow. This is not always the case however, vacuum tubes can hit mean drift velocities that are a good fraction of the speed of light. \$\endgroup\$ – Dan Mills Aug 23 '18 at 11:10
    \$\begingroup\$ I count that as static electricity, because it's about strong electric fields and moving charge carriers. \$\endgroup\$ – Janka Aug 23 '18 at 12:15
  • \$\begingroup\$ It may be instructive to calculate the mean drift speed of the electrons in a 1mm^2 copper wire carrying a current of say 1 amp, it is rather small. \$\endgroup\$ – Dan Mills Aug 23 '18 at 13:44
