-6
IN inductor current lag voltage by 90 if resistance and inductor is series .if laging current goes to resistor what happen .please explain about current from inductor to resistor
closed as not a real question by Olin Lathrop, Brian Carlton, stevenvh, Dave Tweed, W5VO Oct 6 '12 at 4:34
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, visit the help center. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Huh? It is difficult to tell what is being asked here. \$\endgroup\$ – Olin Lathrop Sep 1 '12 at 12:24
The resistor doesn't care about the current through the coil and its phase with voltage. The resistor is a linear component whose current is only determined by the voltage across it.
So it's possible that due to the phase difference the voltage across the coil is negative with respect to the current, that's when the coil is a power source when it releases its magnetic energy. Then the current in the resistor will flow in the opposite direction. That current may come from the coil or other components.
