I've been trying to make a current source, and have finally gotten my hands on some LM8261's which should be an 'unlimited cap drive' op-amp. The problem is, it is still oscillating.
This is the schematic and PCB layout:
pcb layout
I have tried to route the ground inside the loop area, close to the 5V connection for the opamp, so I could place the bypass capacitors as close as possible. Although the bigger 10uF cap has one of its legs at the groundplane (forgot to include this cap in the schematic picture.)
This is what it looks like when I probe the gate of the MOSFET:
scope1
It's all over the place.
I tried adding a 10uF capacitor across the DUT, so from VDD to ground. This removed a lot of the wierd noise and made it look almost like a sinewave:
I've tried with and without the gate resistor R1, it didn't seem to make any difference.
What is going on? Any clues on why this just doesn't work?
EDIT:
Solved it! With the help from @Andyaka below, I used his solution of inserting a BJT emitter follower in between the op-amp and the MOSFET, together with an integrator and got some great results!
Final circuit:
final
The simulations can be seen here:
https://imgur.com/a/tBprTjh
The gain/phase bode plots I made on the PCB:
G/P plot
Bandwidth of approximately 350kHz! Very pleased.
    \$\begingroup\$ Try this i.stack.imgur.com/wxc0K.png \$\endgroup\$
    – G36
    Aug 25, 2018 at 16:03
  • \$\begingroup\$ @G36: Yes reducing the bandwidth like that could maybe do the trick, but that was the point of using the the LM8261, this shouldn't be necessary. I dont want to stablize it to death, i want to have some kind of bandwidth, like a 100kHz or 200kHz loop bandwidth maybe :) \$\endgroup\$
    – Linkyyy
    Aug 25, 2018 at 16:07
  • \$\begingroup\$ @Linkyyy G36 is correct, though. You pretty much need to do that, or something similar. (I think Andy's and Mat's answers completely missed this problem, the one that G36 readily caught for you.) \$\endgroup\$
    – jonk
    Aug 25, 2018 at 17:05
  • \$\begingroup\$ @jonk: But why? The op-amp should be able to handle this load, shouldn't it? \$\endgroup\$
    – Linkyyy
    Aug 25, 2018 at 17:18
  • \$\begingroup\$ @Linkyyy Do a Bode plot. It should become pretty obvious when you look at it without the capacitor in place. \$\endgroup\$
    – jonk
    Aug 25, 2018 at 17:20
7
I've been trying to create a current source, and have finally gotten my hands on some LM8261's which should be an 'unlimited cap drive' op-amp.
Finding a chip that can drive a capacitive load is one thing but then using a 1 kohm in series with the output to drive that capacitive load is asking for trouble.
Reason: the 1 kohm and the MOSFET gate-source capacitance form a low pass filter within the feedback loop and push the phase margin of the op-amp to 0 degrees at a moderate to high frequency turning the circuit into an oscillator.
Look at the phase margin in the data sheet and note that if you factor in the 1 kohm resistor and about two-thirds of the gate source capacitance, the phase margin graph turns into the blue line I drew below: -
And, the phase margin crosses zero degrees (i.e. it becomes an oscillator) at about 1 or 2 MHz (magenta circle). How did I do this you may ask?
Well even though there is a resistor in the MOSFET's source it doesn't do very much for reducing the gate capacitance - it might reduce it to about two-thirds so, 900 pF GS capacitance and a 1 kohm resistor form a low pass filter with a 3 dB point at 265 kHz. At that frequency the extra phase introduced is 45 degrees hence I drew a red dot 45 degrees lower.
Then I considered a frequency that is five or ten times higher just so I could roughly pin-point where the added phase shift limits at about 90 degrees and drew the 2nd red dot.
Then I joined up the two dots in blue and drew a magenta circle where phase margin is modified to 0 degrees (the point of closed loop oscillation where negative feedback becomes exactly positive feedback.
It's not a massively accurate technique but can tell you whether you are going to hit trouble.
  • \$\begingroup\$ I didn't have any gate resistor in the first place actually, and it was still oscillating. I tried a few values, 100ohm, 1k, to see if it would make a difference, but it didn't \$\endgroup\$
    – Linkyyy
    Aug 25, 2018 at 17:17
  • \$\begingroup\$ @Linkyyy the op-amp itself has internal resistance in its output that will do the "bad-job" just as effectively except that the oscillation frequency will likely be higher because the resistance is smaller. \$\endgroup\$
    Aug 25, 2018 at 17:43
  • \$\begingroup\$ That makes a lot more sense actually. the output resistance of the op-amp might be pretty significant because the mosfet is inside the feedback loop. What kind of bandwidth do you think is achieveable in a op-amp/mosfet configuration? i was hoping for something like 100kHz or more, but it seems like that is kinda impossible with a mosfet with this amount of input capacitance.. \$\endgroup\$
    – Linkyyy
    Aug 25, 2018 at 18:27
  • \$\begingroup\$ A lot of folk use BJTs for this reason but if you need the output drive currents from a MOSFET then you could experiment with a BJT emitter follower driving the MOSFET - this will mean that the 1 kohm resistor can be ditched because now the op-amp is driving a higher impedance due to the insertion of the BJT. The BJT emitter will probably need 330 ohms to 0 volts to achieve high frequency performance and connect this to the MOSFET gate.... \$\endgroup\$
    Aug 25, 2018 at 18:37
  • \$\begingroup\$ ... If all you succeed in doing is pushing the oscillation frequency up several MHz then that is a start because then you might be able to drop 33 pF (or thereabouts) between op-amp output and inverting input to remove a little HF gain and you might get lucky. I would heartily recommend simulation first - try and get it to "sing" at about 1 MHz and then try the BJT buffer. MOSFET based constant current circuits operating at more than a few tens of kHz are tricky. \$\endgroup\$
You are most probably using the same power supply to generate (VDD) and (+5V). Then when the op-amp raises the gate's voltage level, the mosfet sinks too much current, Causing a drop on VDD and +5V. This turns off the op-amp momentarily which causes the oscillation.
  • \$\begingroup\$ I ran the 5V rail and the VDD rail on 2 seperate units, specifically to make sure this didn't happen :) \$\endgroup\$
    – Linkyyy
You need to realize that "unlimited cap drive" doesn't buy you anything in this particular circuit, since it is not actually driving a capacitor directly. With a Vdd of 5 volts and a 1k gate resistor, the maximum current required will be 5 mA. Or, if you like, the minimum impedance on the output is 1k.
Furthermore, in addition to the loading issue, you have an extra gain stage (the FET) which will surely complicate the loop behavior.
