A voltage of 200V is applied to a tapped resistor of 500 ohm. Find the resistance between two tapping points connected to a circuit needing 0.1A at 25V. I have solved this problem with two approach. But the correct answer is coming only by one approach. Fig.1
Total resistance is Ra+Rb = 500 ohm.
Va+Vb = 200V ; Vb = 25V ;
Hence Va = 175V.
Applying KCL at the tapping point we get:
-I + 0.1 + 25/Rb = 0 ; I = 0.1 + 25/Rb;
Va = I.Ra;
175 = (0.1 + 25/Rb)(500-Rb)
If we solve we will get Ra = 420.85 ohm and Rb = 79.15 ohm.
So far so good.
Fig.2
Consider second image in which Ra and Rb variable are taken such that Ra + Rb = 500 ohm
Va = 175V
-I + 0.1 + 25/(500-Ra) = 0 ; I = 0.1 + 25/500-Ra;
Va = I.Ra;
175 = (0.1 + 25/500-Ra)(Ra)
If we solve we will get Ra = 2079.15 ohm.
which is wrong, but I am unable to understand the flaw in the second case. It is perfectly fine. The answer is not correct. Just by changing the way variable are taken the answer is changing.
  • \$\begingroup\$ Shouldn't it be Va = IRa in both cases? \$\endgroup\$ – Transistor Aug 26 '18 at 8:35
  • \$\begingroup\$ Yes, Va = I.Ra ; I have changed. \$\endgroup\$ – TapasX Aug 26 '18 at 8:52
  • \$\begingroup\$ And did you recalculate? Did it solve the problem? \$\endgroup\$ – Transistor Aug 26 '18 at 9:04
  • \$\begingroup\$ There is nothing to recalculate. I had forgotten to put Ra in place of R. Calculations remains same. \$\endgroup\$ – TapasX Aug 26 '18 at 11:10
The flaw is that this equation has some restrictions when applied to a real circuit. From a mathematical perspective the second solution is correct. But as still applied that
\$Ra=500\Omega-Rb\$
you would end up with a negative resistance for
\$Ra = -1579\Omega\$
In the real world such a thing doesn't exist and therefore the solution is not applicable for your problem.
  • \$\begingroup\$ If Rb is less than 500, then Ra will be always positive. \$\endgroup\$ – TapasX Aug 26 '18 at 11:14
  • \$\begingroup\$ I agree yes... but that doesn't change the fact that one of your solutions is resulting in a negative Ra \$\endgroup\$ – Humpawumpa Aug 26 '18 at 15:33
