For t<0 the switch is opened.
Att=0 the switch is closed. The problem asks for the behaviour of i(t) after closing the switch. I tried to solve it with KVL but result is different from the book. The current i(t) for t<0 is 1.73A. So I converted the above circuit to the Laplace domain.
Then I applied KVL and I found a current and
Using the inverse Laplace the result is different from the one in the book wich is found using differential equations in the time domain. Can someone try to solve the circuit? Thanks
  • \$\begingroup\$ What solution does "the book" provide? What result do you get, expressed as a function of time? \$\endgroup\$ Aug 27, 2018 at 0:37
  • \$\begingroup\$ How do you get the 17mV initial condition; it looks wrong? Probably better to do the analysis with the current source rather than convert to a voltage source. \$\endgroup\$
    – Chu
    Aug 27, 2018 at 8:49
  • \$\begingroup\$ @ElliotAlderson the result of the book is $$ I(s) = -63.6e^{-638.2t}+7.72e^{-861.8t}+17.27+19 $$ \$\endgroup\$ Aug 27, 2018 at 9:15
  • \$\begingroup\$ @ElliotAlderson mine is $$I(s) =4247.46e^{-638.2t}+4245.73e^{-861.8t}$$ \$\endgroup\$ Aug 27, 2018 at 9:25
  • \$\begingroup\$ @Chu I found it considering the inductor as a wire in stationary conditions and it is the same of my book. Which value do you think is correct? \$\endgroup\$ Aug 27, 2018 at 9:28
The voltage, \$\small V(s)\$ at the top node, for each branch, is given by:
$$\small V(s)= \frac{19}{s}\small -I_1(s)$$
$$\small V(s)=I(s)\left(\frac{s}{100}\small+10\right)-0.017$$
$$\small V(s)=\left((I_1(s)-I(s)\right)\frac{500}{s}$$
where \$\small I_1(s)\$ is the source current.
Solving simutaneously: \$\small I(s)=\large\frac{1.727}{s}+\frac{7.72}{s+861.8}-\frac{7.72}{s+638.2}\$
Giving the time function: \$\small I(t)=1.727+7.72e^{-861.8t}-7.72e^{-638.2t}\$.
By inspection of the diagram, \$\small I(t) =1.727 A\$ is the correct current for \$\small t=0 \$ and \$\small t=\infty\$.
  • \$\begingroup\$ Have you applied KVL after the convertion? \$\endgroup\$ Aug 28, 2018 at 0:18
  • \$\begingroup\$ I've written three expressions for the voltage at the top node, then solved the three simultaneous equations. Note: The inductor current must be 1.727A at t=0 and at t=infinity. Are you writing the initial condition as 0.017/s? It should be just 0.017. \$\endgroup\$
    – Chu
    Aug 28, 2018 at 8:11
  • \$\begingroup\$ Thank you very much! I have a last question. I imposed the initial condition with the voltage generator for the inductor but I can't figure out how to impose the condition for t=infinity. I mean how can the Laplace method takes in consideration the final condition, when I solve the same circuit with the differential equations I have to use the condition at t=infinity \$\endgroup\$ Aug 28, 2018 at 8:18
  • \$\begingroup\$ There is no need to impose a condition at infinity, I only used this to verify the equations - see my updated answer. \$\endgroup\$
    – Chu
    Aug 28, 2018 at 8:56
