I have created a 4 bit counter with the following inputs and outputs
clockN: active low clock
clearN: active low clear
cP: When high, the counter counts. When low, the counter stays the same.
eP: Active high. This activates the tri-state buffer at the outputs
When I simulate this, and assert the clearN (N meaning active low) at t=0, it does not actually clear until the next positive clock edge. I do not understand why. Also, each time qOut counts up by one, it does it on the positive clock edge even though my code is telling it to do it on the negative clock edge. My code, testbench, and modelsim output are shown below.
Here is the counter code
--Program Counter for SAP-1
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL; --This is required when doing additions to STD_LOGIC_VECTORs
ENTITY PROG_COUNT_SAP_1 IS
GENERIC(size: INTEGER:= 3); --This is the size of the register
PORT(
clockN, clearN, cP, eP: IN STD_LOGIC;
qOut: OUT STD_LOGIC_VECTOR(size DOWNTO 0));
END PROG_COUNT_SAP_1;
ARCHITECTURE Behavioral OF PROG_COUNT_SAP_1 IS
SIGNAL valueBeforeTriBuffer: STD_LOGIC_VECTOR(size DOWNTO 0);
BEGIN
PROCESS(clockN, clearN, cP, eP)
BEGIN
IF(clearN = '0') THEN
valueBeforeTriBuffer<=(OTHERS=>'0');
ELSIF (falling_edge(clockN)) THEN
IF (cP = '1') THEN
valueBeforeTriBuffer<= valueBeforeTriBuffer + 1;
END IF;
END IF;
IF (eP = '1') THEN
qOut<= valueBeforeTriBuffer;
ELSE
qOut<=(OTHERS=>'Z');
END IF;
END PROCESS;
END Behavioral;
Here is the testbench
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity TB_PROG_COUNT_SAP_1 is
end TB_PROG_COUNT_SAP_1;
architecture test of TB_PROG_COUNT_SAP_1 is
--create time constant
constant CLOCK_PERIOD: time:=2 us;
--create constants for all generics.
constant size: INTEGER:=3;
--create signals for every port
signal clockN: std_logic;
signal clearN: std_logic;
signal cP: std_logic;
signal eP: std_logic;
signal qOut: std_logic_vector(size DOWNTO 0);
begin
dut: entity work.PROG_COUNT_SAP_1
generic map(size=>size)
port map(clockN=>clockN,
clearN=>clearN,
cP=>cP,
eP=>eP,
qOut=>qOut);
--simulate the clock
clockNSimulation: process
BEGIN
FOR count IN 1 TO 16 LOOP
clockN<= '0';
wait for CLOCK_PERIOD/2;
clockN<='1';
END LOOP;
END PROCESS clockNSimulation;
--simulate the clearN
clearNSimulation: process
BEGIN
clearN<='0';
wait for 3 us;
clearN<='1';
wait for 7 us;
clearN<='0';
wait for 2 us;
clearN<='1';
wait;
END PROCESS clearNSimulation;
--simulate the cP
cPSimulation: process
BEGIN
cP<='1';
wait;
END PROCESS cPSimulation;
ePSimulation: process
BEGIN
eP<='1';
wait;
END PROCESS ePSimulation;
end architecture test;
