TL;DR: The BSD file from Intel doesn't match the datasheet. What are the right dimensions?
BSD: https://www.intel.com/content/dam/altera-www/global/en_US/others/support/devices/bsdl/10M02SCM153.bsd
Datasheet: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/packaging/04r00471-00.pdf
So I was drawing a max 10 (10M02SCM153) and afterwards saw that you can download the BSD files from Intel (see link above). I crosschecked the imported BSD drawing and the Intel datasheet and came to the conclusion that they don't match. datasheet-BSD
The number and the layout of the pins match.
According to Intel and the datasheet their BSC informations are in milimeters: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07152011_585.html
I have a 10M50DAF484 besides me and measured his dimensions and crosschecked with the datasheet: Everything Ok.
Then I checked the BSD file of the 10M50DAF484 and the dimensions where ok too.
In the case of the 10M02SCM153, which dimensions are the correct ones?
  • \$\begingroup\$ If BSC is 2mm the silk outline is 1mm larger than the package. \$\endgroup\$ – Jasen Aug 28 '18 at 8:04
  • \$\begingroup\$ @Jasen If BSC is 2mm than it would add up for the 10M02SCM153 specification, but than the 10M50DAF484 dimensions wouldn't add up because they match with BSC 1mm. Have you ever seen a datasheet where BSC /= 1[insert your unit here]? \$\endgroup\$ – Eggi Aug 28 '18 at 8:50
  • \$\begingroup\$ unit here seems to be 2mm - feed that in an both pictures agree except for 1mm on the package outline. e=0.5 BSC seems odd, but so is a pachage drawing that give the size of the package, maybe they were a month late... \$\endgroup\$ – Jasen Aug 28 '18 at 9:25
  • \$\begingroup\$ Ok, 10M50 has e=1.0 too, so 16x16 should be okay? But is there any way to recognize, that BSC should be read as 2mm? If I crosscheck with the 10M50 dimensions than all units must be multiplied by 2. \$\endgroup\$ – Eggi Aug 28 '18 at 9:33
  • \$\begingroup\$ no, I can't see any way to get the over-all size information from that data sheet, I was meaning "a package drawing that does NOT give size is unusual, and this one a month late to be an April 1st prank" Alterra has defined BSC as 1mm. comments in the BSC say the same. are you certain that Eagle grid pitch is 0.5mm and not 0.25 ? \$\endgroup\$ – Jasen Aug 28 '18 at 9:50
The datasheet will be correct. Notice the table states that the unit is "millimeters".
I dont know why the Eagle dimensions are wrong. There doesn't seem to be any dimensional data in the BSD file, so I'm not sure how Eagle can interpret it.
In fact, in the BSD file it says at the top:
Package : 8 mm 153 MBGA
Which matches the 8mm of the datasheet.
