I'm interested in having an embedded device send data optically. This is for test and measurement, where having conductive cables is problematic since it will perturb the measurement. The device is built as a prototype now except for the data sending interface. The data rate requirements are moderate (10-20Mbps one way). The distance is short, 5-10ft. This is somewhat power limited, but using 0.2-0.5W for comms is okay.
I looked at IrDA but that seems to be almost completely obsolete, and the data rates are too low (other than the very unavailable UFIR/GigaIR). I also looked at TOSLINK, and that seems to be almost-obsolete, and I can't source fast (125Mbps) transceivers, nor can I figure out how to run the slower 10MBps ones reliably at anything close to their max rated speed.
Now, I could hack some kind of completely proprietary UART-over-fiber protocol, or wait for LiFi, or mod some of the really expensive Corning optical USB cables to not have a power conductor... all of these are problematic in various ways. Then I thought, why not just use SFP transceivers on both ends?
I have only a very basic idea of what is inside a SFP, and essentially no idea how to talk to it. Could someone explain to me how to drive a SFP from a microcontroller? Either (a) a UART-over-fiber using SFP and microcontrollers on both ends, or (b) ethernet using SFP from a microcontroller and regular SFP ethernet device on the other end?
P.S. If it matters, the microcontroller is a STM32F446; I would like to stick with STM32 if possible. The device is battery powered from a 2500mAh lithium ion battery.
P.P.S. I can build devices on both sides of the link; the near side would probably have some kind of optical-to-USB-serial converter, if it is not simply ethernet.
