I have a couple of notes about the half wave rectifiers with the RL load, but I dont quite undestand how is obtained the extinction angle \$\beta\$ ?
Questions
  • \$I_{ODC}\$,\$V_{ORMS}\$
Resolution
First it is calculated the impedance
$$Z=\sqrt{R^2+L\omega^2}$$ $$Z=\sqrt{9^2+((18mH)(60)(2\pi)^2}=11.268\Omega$$ then the angle \$\phi\$
$$\phi=\frac{L\omega}{R}$$ $$\phi=tan^{-1}\frac{18mH*2\pi*60}{9}=36.99$$
Then it is calculated \$V_{ODC}\$
$$V_{ODC}=\frac{V_m}{2\pi}(1-cos\beta)=\frac{\sqrt{2}*180}{2\pi}(1-cos215)=52.11V$$ $$I_{ODC}=\frac{52.11}{9}=5.79A$$ for $$V_{ORMS}=\frac{V_m}{2}\sqrt{(\frac{1}{\pi}(\beta-\frac{1}{2}sin2\beta))}$$ $$V_{ORMS}=\frac{\sqrt{2}*180}{2}\sqrt{(\frac{1}{\pi}(3.75-\frac{1}{2}sin2*215))}=91.997V$$
Discussion
While this seems to be an appropriate use of the definitions of DC and RMS values based on the definition using integrals and taking the idea that this is valid under a sine signal, the main issue is how is calculated the \$beta\$ angle since I see the value of 215 degrees but how was calculated?, I understand that the \$phi\$ angle its the difference of phase between the voltage and the current because of the induction effect, so I'm guessing this is added to \$pi\$ but this would yield 216.99 degrees not 215.
I calculate the \$\beta\$ from $$\frac{V_m}{Z}\sin(\beta-\phi)+\sin(\phi)e^{\beta/\omega\tau}=0$$ using the circuit values
\$\omega\tau=2\pi*60*\frac{18mH}{9}=.753\$ in rads and the actual value from \$phi\$ in rads=0.645 so making the substitution on the equation before, it would be $$\frac{\sqrt{2}*180}{11.268}\sin(\beta-.645)+\sin(.645)e^{\beta/.753}=0$$ Solving for \$beta=0.642\$ rads or 36.78 degrees, then this added to \$pi\$ would be 216.78 not 215. But why or how its justified I don't know. I cant attend the lectures because of the job so I don't have more info and the people that I contacted does not know, even didn't notice this. It seems that the \$phi\$ value is used instead of \$\beta\$ and in this case are almost the same, but I have tried to solve problems like this and the values have a greater difference of 30 or 40 degrees, so I cant assume that the \$phi\$ values are used as an approximate to avoid solving the last equation, that I understand does not have a closed form solution.
    \$\begingroup\$ Is the difference due to the diode drop and Ri not included in your answer? \$\endgroup\$ Aug 30, 2018 at 16:44
  • \$\begingroup\$ @TonyEErocketscientist, no It is not contempled, the diodes and the source are considered ideal. \$\endgroup\$
    – riccs_0x
    Aug 30, 2018 at 16:55
    \$\begingroup\$ I think your solution is correct. I simulated 36.72 deg with a Si diode and 36.50 deg without. tinyurl.com/yd8ssfc3 converting 1.67 to 1.70ms time interval to phase. but the "real world" has diode capacitance and resonant noise when the diode is off. so close enuf for gov't work \$\endgroup\$ Aug 30, 2018 at 17:34
    \$\begingroup\$ No @riccs but I have experience suppressing the noise with an RF cap. You should try it. You know that diodes have capacitance I hope. \$\endgroup\$ Sep 3, 2018 at 4:51
    \$\begingroup\$ yes when reverse biased they become varicaps, with more pF towards 0V with a characteristic curve. \$\endgroup\$ Sep 3, 2018 at 13:44
For the uncontrolled single-phase rectifier with RL load: In order to find the \$\beta\$, the extinction angle, the following equation must be solved:
$$sin(\beta-\phi)+ sin(\phi)e^{^-\frac{\beta}{\omega\tau}} = 0$$ where \$tan\phi = \frac{\omega L}{R}\$, Also, can be written as: $$sin(\beta-\phi)+ sin(\phi)e^{^-\frac{\beta}{tan\phi}} = 0$$
The equation is transcedental and can be solved only by numeric methods. Using the values you supplied: \$ \phi \approx 37\$ degrees. Solving equation numerically: \$\beta \approx 217\$. Alternatively, \$\beta(\phi)\$ can be determined by using pre-built plots, like the one shown below (in accordance with the calculation above):
Beta from phi
The approximation you mentioned (also in another post similar to this, which you deleted) does not seem always to work . Note, for \$0 \leq \phi\leq 40\$ degrees the curve seems a straight line, being enough to do \$\beta=\phi+180\$ degrees. But, using the plot, for \$\phi=70\$ degrees, \$\beta=260\$. Your approximation lead to \$\beta=250\$, something different.
    \$\begingroup\$ For R=1, I get 5.08ms extinction or 180+109 deg. due to group delay? when phase angle approaches 90 deg. extinction exceeds 90deg. \$\endgroup\$ Aug 30, 2018 at 18:11
    \$\begingroup\$ The botton left point on curve refers to "pure resistance" and upper right point refers to "pure inductance". \$\endgroup\$ Aug 30, 2018 at 18:26
    \$\begingroup\$ I got that part but missed the fact that extinction goes to 0 when R goes to 0 meaning 360 deg or Continuous conduction and phi angle of 75 deg becomes 180+90 deg for Beta, so my simulation is correct too. \$\endgroup\$ Aug 30, 2018 at 18:57
    \$\begingroup\$ In other words: The OP approximation could be something valid for a small time constant (L/R). \$\endgroup\$ Aug 30, 2018 at 20:20
    \$\begingroup\$ You can use that I provided or build it yourself, for example through a Matlab script (fzero). Some books of Power Electronics included it, too - when presenting single phase uncontroled rectifiers (RL load). \$\endgroup\$ Aug 31, 2018 at 16:30
