How would I make a 4-bit shift register with D flip flops so that only 1 LED is active at once. So for example if a button was pushed the first LED would light up and the other 3 would be off. If the button was pushed again the second led would light up and the other 3 would be off etc. I want to be able to do this with 4 LEDs.
This is what I've tried but I can't seem to be able to get it to work. Any help is appreciated as I've just started to learn.
Something like this should work.
Note: the LED part and resistor values were just the defaults when dropped onto the schematic. They would likely need adjustment in a real circuit.
Or here it is in Falstad, so you can see the simulation.
There are two types of shift registers:
First: Series in Series out (SISO)
Second: Series in Parallel out (SIPO)
I used a button in Logisim as a manual clock .
