There is a scenario based question which is confusing for me Antenna had four rods each 15cm arranged as a plus sign. its brass shielding was cut and it had two 75 ohm coaxial cables in it. one 10 cm long was connected to rod A and C whereas other was 17.5cm long connected to rod B and D. On measurement you found good impedance match between antenna and cable. both the cable got combined at the other end into one input connector
  1. Find Center Frequency
  2. Predict polarization
  3. Plot radiation pattern.
Can you tell me how impedance matching works, do length matters and how can we know if antenna with given length is having a good match with coaxial cable with given length
Antenna Question
    \$\begingroup\$ Welcome to EE.SE! This appears to be a homework question. As such, you need to show us your work so far, and explain which part of the question you're having trouble with. For future reference: Homework questions on EE.SE enjoy/suffer a special treatment. We don't provide complete answers, we only provide hints or Socratic questions, and only when you have demonstrated sufficient effort of your own. Otherwise, we would be doing you a disservice, and getting swamped by homework questions at the same time. See also here. \$\endgroup\$
    – Dave Tweed
    Sep 2, 2018 at 14:15
Since this is homework, here are some hints:
  • The dimensions of the antenna elements determine its intended operating frequency.
  • Mismatched cable lengths create a phase shift in the signal. The phase angle is a function of the cable length and the operating frequency.
  • Crossed dipoles fed with different signal phases is one way to produce circular polarization.
  • \$\begingroup\$ Thankyou Dave. Hints were very helpful \$\endgroup\$ Sep 2, 2018 at 18:11
