We know that ADC 1LSB=Vref/(2^N) where N is the resolution of the ADC.
We know that ADC Effective number of bits (ENOB) is always less than the resolution "N".
When calculating 1LSB do I need to take 1LSB = Vref/(2^ENOB) or I need to take 1LSB=Vref/(2^N)
The LSB {not to be confused with LSB for byte, lsb for bit} is always the average analog level between all consecutive binary encoded voltages. Thus full analog scale is used, not from midscale, nor ENOB.
\$\text{LSB=Vref}/2^N\$ for N bit ADC and Vref is the max. analog unipolar value.
Otherwise for bipolar voltage input , one uses the full-scale range(FSR) ADC's \$\text{LSB=FSR}/2^N\$
other info
Alternatively, SNR = 6.02N + 1.76dB so for N=8 bits, ideal SNR~50dB. The ENOB indicates the binary number of bits in resolution, limited by noise.
The ENOB dynamic range over asynchronous noise, distortion and ADC error sources measured in binary exponent bits and is best-case near full-scale. This value must be de-rated by the analog (full/actual ratio minus 1) for much smaller signals and is reduced due to ADC errors including non-monotonic, gain & offset errors and noise errors.
For Analog data ENOB is defined as \$\text{ENOB}=\dfrac{\text{SINAD-log}(1.5)}{\text{log}(2)}\$ where the 1.5 is the ideal ADC quantization error and \$\text{SINAD}=10\log \left(\dfrac{\text{(signal+noise+distortion) power}}{\text{(noise+dist.) power}}\right)\$
ENOB helps to define the logarithmic dynamic range.
  • the threshold for marginal speech is 12 dB or 4:1 or ENOB = 2
  • an 8 bit ADC has a practical max ENOB=7.1 typ.
  • a 12 bit ADC has a ENOB = 10.5 typ.
When using a serial data link with synchronous noise from overshoot or frequency dependent of data pattern dependent precompensation equalization, the Link term LENOB is used which uses Vpp levels instead.
thus \$\text{LENOB=log}_2\text{(SNR[Vpp])} \$
  • The LENOB for data varies from 3 (best case) to 4 bits (typ) for \$10^{-12}\$ BER but this is the minimum threshold value and it rises with data rates since a higher SNR is needed to maintain the same error rate in a channel and has other variables.
Have you read the Wikipedia page about ENOB?
The designed value of an LSB is \$1 LSB = \frac{V_{ref}} {2^n}\$
Due to non-idealities ENOB is less than n
That still means that you need to treat the ADC as if it was ideal and as designed.
An example: \$V_{ref} = 2.56 V\$ and \$n = 8\$ then ideally \$1 LSB = \frac{2.56V}{8^2}= 10 mV \$
Now assume that the \$V_{ref}\$ I'm using is very noisy and this reduces ENOB from 8 to 7 bits. Then the LSB bit is still there but it will be so noisy (random) that I cannot use it. A 10 mV change (1 LSB as designed) at the input of the ADC will not be detected in the output as it will disappear in the noise.
A (2x 1 LSB as designed) 20 mV change however should be detected, the LSB +1 bit will change. This means that 1 LSB is still 10 mV, you just cannot use it (unless you average a lot of samples so the noise averages out but that's a different scenario).
When calculating 1LSB, take 1LSB=Vref/(2^N).
When considering spurious and other unwanted signals, take their voltage to be estimated by Vref/(2^ENOB).
Note that when you've calculated 1 LSB, you might hope it means that when you make that increment to the voltage into the ADC, the output number increases by 1. It doesn't. Read the data sheet carefully for what is guarranteed. A 'no missing codes' spec will guarrantee you see all the possible output numbers at some time or another. A monotonic spec will guarantee that as the input voltage goes up, the output code will never go down.
    \$\begingroup\$ Understanding ADC specmanship could fill a large book! \$\endgroup\$ Sep 4 '18 at 11:25
  • \$\begingroup\$ Hi Neil ,I am using this IC from AD (analog.com/media/en/technical-documentation/data-sheets/…) It shows Resolution MIN 14bits no missing codes.Does that mean I will always get 14bit performance from it \$\endgroup\$
    – Hari
    Sep 5 '18 at 6:26
    \$\begingroup\$ @Hari '14 bit performance' is meaningless, until you specify your application, and how you want to use it. That is a DC-reading device, so if that hints at your application, you ought to be looking at things like TUE (total unadjusted error), offset, drift rate, noise. If you read note 2 in the data sheet, which qualifies no missing codes, it's by design, not tested, which hints at what sort of ADC they're using (rules out SAR). Rules for choosing an ADC - specify exactly what you want to do, what errors you will and won't tolerate, then choose device that gives that. \$\endgroup\$
    – Neil_UK
    Sep 5 '18 at 8:00
  • \$\begingroup\$ @Neil,I am using that ADC for current measurement purpose. \$\endgroup\$
    – Hari
    Sep 6 '18 at 7:05
