Need to connect and charge two Li-ion batteries in series. I'm not sure if it is possible to connect and use two Li-ion batteries and TP4056 like this. Are they going to be balanced? Do they need to?
  • \$\begingroup\$ No, you can't do that. Probably IN- and BAT- are connected together. Now look at your 5 V in. It will connect to BAT- of the top board and put +5 V on the BAT+ of the lower board. \$\endgroup\$ – Transistor Sep 4 '18 at 15:03
  • \$\begingroup\$ That's why i connected top li ion between 10V and 5V, and the last one between 5V and 0. So top bat should be ok (?) \$\endgroup\$ – Рональд Sep 4 '18 at 15:26
  • \$\begingroup\$ No. It's just a very bad solution. You can see in Tony's answer that R2, for example, is between the BAT- and IN-. (It's probably a low value for current sensing.) If you connect BAT- to BAT+ of the lower board you will completely mess this up. \$\endgroup\$ – Transistor Sep 4 '18 at 15:34
Thus your problem now looks like this.
"No Way, Jose".
Yes they need to be balanced to prevent accelerated aging from mismatch charge imbalance with high current and deep discharges.
  • It is analogous to runaway series incandescent lightbulbs ( where the faster weaker bulb achieves near full brightness and the other bulb stays cool.
  • Another example is like mismatched-Vf shunt LEDs sharing current. If one LED cannot support the current of 2 or more in parallel, one can burn out open cct as thermal runaway lowers the Vf of the hotter LED thus drawing more current.
    There is a better chance of extending end-of-life to achieve the max rated charge cycles if they are balanced or much lower if they are not!
