I would like to design an old-school pseudorandom pulse generator to trigger various types of events (hardware suggestions only please - no programmable ICs). The events that I want to control need to happen, generally speaking, in the following categories of frequency: many times a minute, a few times a minute, once a minute, once every few minutes, once or twice an hour. Within each category of frequency, the event should occur "randomly," which is to say, the event's recurrence should not be exactly predictable. To give you a sense for why I want to build this: imagine a video game that has various scene elements, some of which occur very often, some that happen pretty frequently, and others which are infrequent... you get the idea, I hope.
The reason that I would like a hardware-only solution is that I am purposefully trying to learn about discrete logic - things like shift registers, multiplexers, Boolean logic, etc. Efficiency, speed, size, and cost are not my primary concerns. Hopefully there are some vintage electronics fanatics out there who will help me in my quest for knowledge! Thanks :-) PS: a drawn schematic would be tremendously appreciated since I am learning and probably won't be able to understand or build vague suggestions.
  • \$\begingroup\$ Welcome to EE.SE. By not using MPU's to program, you need many stages to randomize the original data stream. \$\endgroup\$ – Sparky256 Sep 6 '18 at 0:58
  • \$\begingroup\$ cant you search google images? \$\endgroup\$ – Sunnyskyguy EE75 Sep 6 '18 at 0:58
    \$\begingroup\$ This nerdist.com/wall-of-lava-lamps-protect-internet-traffic is the ultimate analog random number generator \$\endgroup\$ – crj11 Sep 6 '18 at 1:07
    \$\begingroup\$ Shift registers, and multiplexers are generally considered digital devices, not analog (though there is also a device called an analog multiplexer). Boolean logic is the mathematics behind digital logic. If you want to make your design from individual gates and flip-flops, we'd call that a design from "discrete logic devices", not "analog computation". \$\endgroup\$ – The Photon Sep 6 '18 at 1:13
    \$\begingroup\$ The lava lamp device is meant to produce truly random output, not pseudo random. And just about any device you make with actual analog devices is likely to be the same ---- random rather than pseudorandom. \$\endgroup\$ – The Photon Sep 6 '18 at 1:14
A good way to generate randomness using discrete logic is to exploit the metastability characteristics of a flip-flop.
A D flip-flop is a type of flip-flop that has a clock (triangle looking input) and a data input (D input) as shown below. Normally, the state of the D input is transferred to the Q/!Q output one propagation delay after a rising edge on the clock.
D Flip Flop
(from http://www.learningaboutelectronics.com/images/D-flip-flop.png)
The data must "set up" a specific amount of time before the clock edge and "hold" a specific amount of time after the clock edge in order to assure that the input is correctly transferred to the output. If the setup and hold times are not met, then the state of the output at the normal propagation delay time for the flip flop becomes random. The randomness can be tuned by varying the frequency and phase of the clock and data and the amount of time that you wait to check the state of the output.
The graph below is from a TI paper that discusses the metastability characteristics of various 5V logic families. In general, the slower the logic, the worse the metastability and the more often random errors occur. This means that older logic families are more useful for generating random errors. The graph shows that using 74HC style logic, the error rate can be tuned from thousands of times per second to once per day by varying the wait time after a clock at which you look at the output of the flip-flop (tx). This specific graph is for a 1 MHz clock and a 500 KHz data input.
Note that metastability is delay, temperature, and voltage sensitive, so tuning to a specific event rate could be challenging. But it might be possible to build something good enough for your needs.
The test circuit from the TI paper is shown below. It can be a starting point to a random event generation circuit.
metastability test circuit
  • \$\begingroup\$ @KellyHeaton If you feel that the answer is helpful, please upvote it. After a while, choose the best answer and accept the answer. \$\endgroup\$ – Hazem Sep 6 '18 at 2:59
  • \$\begingroup\$ @Hazem I would happily upvote but don't see an option in my interface (I think because I am a new user I don't yet have this privilege). Plus, I am still considering the different answers - there isn't only one. \$\endgroup\$ – Kelly Heaton Sep 6 '18 at 3:04
The answer to this question is that there are many answers, but the most common approach is to use a linear feedback shift register. I started with this idea and breadboarded two 8-bit shift registers (TI part CD54/74AC164E) clocked by a 555 timer in astable mode. I left the data serial inputs of the shift registers floating. Prior to adding XOR gates (the linear feedback part), I tested this circuit with LEDs to visualize what is happening. As it turns out, the two shift registers start out in different states (presumably because their data inputs are floating). Their states remain unsynchronized as they continue to shift, which you can see in this video:
https://www.kellyheatonstudio.com/blog/2018/9/6/shift-registers
The two 8-bit shift registers are in the center region of my breadboard. On the right is a 555 timer in astable mode which provides a clock pulse of about 1x per second. On the left is a 5 volt regulator - this part is irrelevant if you have the correct DC supply voltage, but mine is 12 VDC.
Perhaps this hacked approach is all the apparent randomness that I need (I am an artist, not a cryptographer). If not, I will add linear feedback and/or follow @crj11's advice below regarding the exploitation of the metastable characteristics of flip flops (which are what's inside of the shift registers). Either way, I think by using multiple shift registers and multiple 555 timers I won't need a lot of feedback and certainly nothing fancy in order to make the system appear random --even though it's not, technically.
As for the frequency of my events (often, sometimes, rarely...), I plan to clock different shift registers at different speeds. Applying logic gates to the outputs of these different registers (at different clock speeds) should give me the general categories of event frequency that I am seeking, since faster clock speeds will result in more logical "positives" (or whatever is the correct terminology). I hope this makes sense.
Below are a few resources for people who, like me, don't know the correct terminology or understand how shift registers are used for pseudorandom number generation.
Good general overview to answer the question “what is a linear feedback shift register” (LFSR): https://zipcpu.com/dsp/2017/11/11/lfsr-example.html
On choosing taps for a linear feedback shift register: https://cs.stackexchange.com/questions/1121/choosing-taps-for-linear-feedback-shift-register
Mini project on how to implement a LFSR: https://www.slideshare.net/KishoreChandrahasVanam/lfsr
Another helpful paper on using an 8-bit LFSR (i.e. Texas Instruments chip CD54/74AC164): https://pdfs.semanticscholar.org/320a/8b2e781ac6165b400eca96047489685fd1f7.pdf
