I've recently done an experiment on a 415/100 V transformer. Performing the S/C test on the HV side and the Open Circuit test on the LV side and finding winding resistance from applied DC voltage and current.
Therefore I now have results from the experiment and have solved Magnetizing reactance, core loss Resistance, Copper/winding resistance and Leakage reactance equivalent values, depending on which side I transfer the equivalent values to according to my turns ratio (a).
The issue I'm having is that I cannot find a way to split the equivalent leakage reactance into its 2 components (LV winding and HV winding).
Equivalent winding resistances are split into their 2 values from the measured applied DC voltage and current Test.
I was beginning to think that if I had measured the voltage across the S/C side in the S/C test (although it would be small, it would still exist) I would have had enough unknowns to solve for Xl LV side; but because I did not measure that voltage assuming 0 volts, I cannot.
Any ideas? I'm stumped.
