How does a wifi transciever placed inside a Pringles can act as a wifi signal booster. I saw this trick on Mr robot TV series. Do WiFi routers emit less power than GSM or LTE. I know for :
GSM - 2W (33dbm)
LTE - 200mW (23dbm)
closed as unclear what you're asking by pipe, winny, Dmitry Grigoryev, awjlogan, Elliot Alderson Sep 27 '18 at 14:38
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • 9
    \$\begingroup\$ Not booster, directional (c)antenna \$\endgroup\$ – PlasmaHH Sep 6 '18 at 7:05
  • \$\begingroup\$ Wifi: 100mW when using 2.4 GHz. The 5 GHz band uses more power. \$\endgroup\$ – Turbo J Sep 6 '18 at 7:09
    \$\begingroup\$ @TurboJ that statement is as far as I know wrong, and even if it isn't, the amount of power you may use depends on local jurisdiction, so you certainly can't make general statements like that. \$\endgroup\$ – Marcus Müller Sep 6 '18 at 7:20
  • \$\begingroup\$ What are limits set by FCC? \$\endgroup\$ – ObsessionWithElectricity Sep 6 '18 at 7:26
    \$\begingroup\$ How is GSM or LTE even related to your question? What are you actually asking about here? \$\endgroup\$ – pipe Sep 20 '18 at 3:04
9
As PlasmaHH says, it doesn't boost the total power - it can't, it's a passive device. Instead it makes the antenna much more directional. Signal behind or to the side will be much weaker. Usually you'll use them in pairs to make a link between two buildings.
Very similar principles to the directional reflectors in flashlights or car headlights.
