This is the schematic.
Both switches are in phase (On and Off at the same times). When both SW are On, current flows through primary transformer coil, entering from the top side of it, and leaving through the dotted side, finally going to the ground through the lower switch. Diode on the secondary does not conduct (reverse biased). Energy is being stored in the magnetizing inductance - an inductor parallel to primary coil of transformer (integrated part of transformer, not shown in the schematic drawing). Output of the converter is energized by output capacitor.
When switches are off, magnetizing inductance provides magnetizing current that enters primary windings of the transformer through the dotted side, and is transferred to the secondary side in such a way that current leaves the dotted side of the secondary, and the diode is forward-biased.
If this is correct, the question arises about the two diodes on the primary side, how do they turn on? When switches are abruptly turned off, leakage inductance (inductance in series with the transformer), will oppose quick current drop, and will induce a voltage of same polarity as input voltage in order to slow down current decrease. This voltage can be quite large and can damage MOSFETs. Finally the question: How exactly do those two diodes turn on? MOSFETs are turned off by external gate-driving circuit, and they will instantly go Off (open circuit). Then how will lower diode draw current, from where? Then, where this current goes, where is it dissipated?
Thanks
    \$\begingroup\$ Normally feedback is 3rd winding or opto-isolated feedback. \$\endgroup\$ Sep 8, 2018 at 14:47
    \$\begingroup\$ A half bridge with centre tap or complementary primary drivers are used \$\endgroup\$ Sep 8, 2018 at 15:04
  • \$\begingroup\$ Note that in this arrangement, you'll have conduction losses over two MOSFETs and flyback losses over two diodes. It may also be challenging to "drive" the top MOSFET properly. You might be able to simplify and reduce losses by using just the lower MOSFET and one diode/snubber network. \$\endgroup\$
    – rdtsc
    Sep 8, 2018 at 15:31
Incorrect. When the switches are off, the current doesn't reverse it ramps down from the previous "charging" positive value to zero. This means that the voltage at the lower MOSFET drain reverses polarity compared with the upper MOSFET's source.
The two diodes steer any excess back-emf to the DC power rail on the primary side. This steering is necessary to prevent leakage inductance on the primary damaging the MOSFETs because the energy contained in leakage inductance is never transferable to the secondary.
Here is my version of your circuit showing the charging voltages in red followed by the energy transfer voltages in blue: -
It's the primary voltage that reverses because the previously positive ramping-up current when the MOSFETs were on (red phase) becomes a negative ramping-down current during the blue phase.
After you turn-OFF both MOSFET. The current in the inductor (primary winding) want to flow in the same direction as before (before the MOSFET was switch-off). Therefore the situation will look like this:
Energy stored and Lagging of Current In a Inductive Circuit
  • \$\begingroup\$ That explains upper diode that returns current to the input (does input sink this current?). But what is the use of the lower diode then? \$\endgroup\$
    – DenR
    Sep 8, 2018 at 16:13
  • \$\begingroup\$ @DenR Current is flowing in this path: the dotted end of the inductor----> upper diode--->Supply source--->GND--->Lower diode--->upper end of the inductor. And that's what I tried to show in the diagram. \$\endgroup\$
    – G36
    Sep 8, 2018 at 16:20
  • \$\begingroup\$ Oh, so bottom diode serves to close the loop! \$\endgroup\$
    – DenR
    Sep 8, 2018 at 16:27
  • \$\begingroup\$ Yep, current always must flow in the closed loop path. \$\endgroup\$
    – G36
    Sep 8, 2018 at 16:31
