This is a widely used circuit for level-shifting I2C signals that will be familiar to many of us here:
Can it be used for shifting UART signals at, say 9600 baud as well? The simulator doesn't see any problems with that idea. Obviously, UART is not a bus topology, but if you isolated this as a circuit between two devices and used one for RX and one for TX would you foresee any problems in doing that?
I recognize that the pull-up resistors don't serve a purpose in a UART context either (because it's a push-pull driver). But I'm thinking about sharing this level shifting circuit electrically in a context where I might be switching back and forth between open-collector and push-pull drivers (UART / I2C).
    \$\begingroup\$ I've used this circuit for UART a bunch with no problems. I was using 115200 baud. UART idles high by default so as long as the driver current is not exceeded then there is no problems leaking the pull up resistors. \$\endgroup\$ – vini_i Sep 8 '18 at 16:57
  • \$\begingroup\$ What are the voltage levels you want to switch between? If one of them is true RS232 then I think the answer is no, it won't work. \$\endgroup\$ – Elliot Alderson Sep 8 '18 at 18:12
  • \$\begingroup\$ @ElliotAlderson 5V and 3.3V as depicted in the schematic. \$\endgroup\$ – vicatcu Sep 8 '18 at 18:27
  • \$\begingroup\$ Really depends on your implementation, path length etc.. Also most logic, even 5V will detect 3.3V as a valid high level, to go from 5V to 3.3V where you can use a simple voltage divisor with 2 resistors. \$\endgroup\$ – Damien Sep 13 '18 at 13:41
