I wonder if there is a way to detect if there is any RF/WiFi radio ON nearby?
I'm configuring an ESP8266 12E module in STATION MODE (not Access Point) to connect to a Wifi network (any Wifi network). So, no problem. However, there is a situation which I'll have to turn off the ESP8266 module's radio (turn it off the radio only ... I'm not talking about disconnecting from the Wi-Fi network).
I already have the code that supposedly turns off the Wifi module ESP8266, which is the one that follows below and seems to work fine:
WiFi.mode (WIFI_OFF);
delay (1);
I just need to know if the radio really turned off, because I have a system in which there are 40 ESP8266 modules operating side by side, connected to the WiFi network and all these radios together are generating so strong interference to each other. When executing the Wifi shutdown code of the module(s), I just want to know whether there was none left without executing the shutdown.
Does anyone know how to detect a simple RF device?
