Which is the best way to convert Ac to DC , with maximum efficiency possible by using a transformer. The required voltage is 5v and current is 1a . I saw a circuit from my mobile phone charger they didn't use 7805 voltage regulator. They first convert Ac to DC using a bridge rectifier and then to transformer. Their circuit is complicated to understand. Can anyone post a link where I can find a circuit diagram.
    \$\begingroup\$ You probably saw a switching power supply, which are high efficiency sources. Linear power supplies are not so efficient compared to the switching ones. \$\endgroup\$ – Blue_Electronx Sep 9 '18 at 4:29
  • 5
    \$\begingroup\$ If you're asking this question, buy a module. AC-DC can be dangerous and is hard to get right if you don't know what you're doing. 5V power bricks have gotten so cheap its not really worth designing anyway. \$\endgroup\$ – Matt Young Sep 9 '18 at 4:48
  • \$\begingroup\$ Warning! Switching power supplies can have as much as 300 VDC at the bridge rectifier, 340 VDC if it has a PFC IC. Suggest buying an open-frame (exposed parts) power supply and probe it with a good DVM and an oscilloscope if possible. You have much to learn before you attempt to build one. \$\endgroup\$ – Sparky256 Sep 9 '18 at 5:26
Switched mode power supplies (SMPS) are the standard method of doing what you require. They are efficient, compact, light weight and, due to mass production, low cost.
See my answer to How does a cell phone charger work? for a brief overview of the operation and identification of the essential parts of an SMPS.
SMPS design is tricky and since mains voltages are involved they are hazardous and difficult to debug. You will not build one for less cost than a commercially available unit so I recommend that you avoid attempting this until you have advanced well in your electronics studies.
