When the components are between each other, can I sum up multiple, alternating series capacitors and resistors like this? Thanks.
1\$\begingroup\$ yes why did you doubt it/ \$\endgroup\$– Tony Stewart EE75Sep 9, 2018 at 7:04
\$\begingroup\$ @TonyEErocketscientist because the components are between each other. \$\endgroup\$– Ivan HuSep 9, 2018 at 7:10
1\$\begingroup\$ Since they share the same current, the end-points cannot tell the difference in an equivalent circuit. Only a real voltage drop on each and power dissipation may be different for power heat rise. \$\endgroup\$– Tony Stewart EE75Sep 9, 2018 at 7:15
1 Answer
