I have recently bought a lidar sensor with a peculiar cable type. I cannot identify it, but it has some interesting characteristics. It has a pitch of 1mm, and each pin has at most a 0.5mm width. The cable itself is for UART, but I'm not sure if the connector was made for it.
Here is a close up of the male end. enter image description here
After a quick search, The cable type appears to be a GH1.25-4P connector enter image description here
  • \$\begingroup\$ This does not seem to match the connector in your previous picture at all. Not the same type of attachment, not the same pitch, not the same edges... \$\endgroup\$
    – jcaron
    Sep 10, 2018 at 23:04
  • \$\begingroup\$ @jcaron I'll double check when i get home \$\endgroup\$
    – tuskiomi
    Sep 10, 2018 at 23:08
  • \$\begingroup\$ It does seems to be a JST-GH connector indeed (which has 1.25 mm pitch, not 1 mm), but your picture here does not seem to match that connector. \$\endgroup\$
    – jcaron
    Sep 10, 2018 at 23:32
