I am doing a course on Coursera "Intro to electronics" as electronics always was my weak point.
Now we discuss npn transistors and I have simplified circuit diagram (see below) where I am supposed to solve for VB. I am feeling really embarrassed to ask this but I want to understand this...
Given are Rb1=15000, Rb2=82000, Vcc=15 and IB=40 mA
My idea was to to a KVL and KCL and I came up with these equations: $$ V_{cc} - I_{b2}R_{b2}-I_{b1}R_{b1}=0 \\ I_{b2} - I_{b1}=I_{b} \\ and \\ V_{b}=V_{cc} - I_{b2}R_{b2} $$
and this becomes
$$ I_{b2}R_{b2} + I_{b1}R_{b1}=V_{cc} \\ - I_{b1}+I_{b2}=I_{b} $$ $$ \pmatrix{ R_{b2} & R_{b1} \cr - 1 & 1}\pmatrix{I_{b1} \cr I_{b2}} = \pmatrix{15 \cr 0.04} $$
When I solve this for IB1, IB2 I get 0.04 mA and 15 mA. This gives me VB = VCC-IB2*RB2 = 14.5055 V
... which incorrect!! :-(
The solution's hint is to use superposition.
My two question: 1. What's wrong with my solution way? 2. How do I go about with a superposition?
EDIT: ad 2: after some more thinking: can superposition in this case mean that I
a) have one circuit without IB.
AND
b) one circuit with both voltage set to ground. Thus I get RB1 and RB2 in parallel?
    \$\begingroup\$ You might want to work on your title, its rather meaningless \$\endgroup\$ – PlasmaHH Sep 11 '18 at 8:42
  • \$\begingroup\$ Yes. That's right. Do you have a good suggestion since I don't have a clue on how title this simple problem... :-( \$\endgroup\$ – Andreas K. Sep 11 '18 at 8:49
    \$\begingroup\$ Ok. I changed it. Hope this has sufficient meaning. Thanks. \$\endgroup\$ – Andreas K. Sep 11 '18 at 8:51
  • \$\begingroup\$ "1 Voltage, 1 Current" isn't a circuit. Can you try once more to clear up the title? Also, please start early on with the schematic in your question. People are differnt, but I look at any schematic first and then read the question. \$\endgroup\$ – winny Sep 11 '18 at 11:16
  • \$\begingroup\$ I am really sorry. I tried my best to find a good title for this problem. And thanks for the hint with the schematic. \$\endgroup\$ – Andreas K. Sep 11 '18 at 13:54
Your KVL looks like this: $$ I_{b2}*R_{b2} + I_{b1}*R_{b1}=V_{cc} \\ - I_{b1}+I_{b2}=I_{b} $$
And if we plug the numbers into WolframAlpha
http://www.wolframalpha.com/input/?i=15+%3D+X2*82+%2B+X1*15,+X2+-+X1+%3D%3D+40
We get
\$I_{b1} = -33.66mA\$ and \$I_{B2} = 6.34mA\$ and \$Vb = 15V - 82k\Omega \cdot 6.34mA = - 504.8V \$
Now we can try the superposition
First I remove the current source, so we are left with this:
The voltage divider output voltage is :
$$V_B' = Vcc*\frac{R_1}{R_2 + R1} = 2.319V$$
Next, we are short-out the voltage source so we are left with this:
Therefore \$V_B'' = - R_1||R_2 * I_B = -507.21V\$
And finally
$$V_B = V_B'+V_B'' = 2.319V + (-507.21V) = -504.8V$$
And we are done.
As you can see there is something wrong with your equivalent circuit.
I suspect that the \$I_B\$ (base current) is equal to \$40\mu A\$ (not \$40mA\$) and in this case \$V_b = 1.812V\$ seems reasonable.
Try to show us the original circuit.
| improve this answer | |
  • \$\begingroup\$ One question: why −R1||R2∗IB? Especially the "-"? \$\endgroup\$ – Andreas K. Sep 11 '18 at 16:19
  • \$\begingroup\$ And yes you are right. They seemed to mix up milli and micro. \$\endgroup\$ – Andreas K. Sep 11 '18 at 16:20
  • \$\begingroup\$ @AndreasK. I put a "minus sign" because of the Ib current direction through resistors. The Ib current is flowing from lower to the upper part of a resistor. So the positive voltage is at the bottom and negative at the top of a resistor (current flow from "+" to "-"). Do you get it? \$\endgroup\$ – G36 Sep 11 '18 at 16:45
