I have been struggling with OpenOCD debugger under Eclipse Neon 4.6.2. Whenever I run the debug configuration I receive below given error message
I have been attempting to debug the STM32F417VGT6 MCU. My debug configuration setting is following
Main tab
Debugger tab
Startup tab
Source tab
Common tab
Have anybody ever had similar problem? Thanks for any ideas.
  • \$\begingroup\$ Please add actual console output. Another suggestion would be to try performing flash-erase and re-flashing via ST-Link utility to verify, that the board is actually flashable and that the error is indeed with eclipse/openocd combination \$\endgroup\$ – stiebrs Sep 27 '18 at 14:10
