I am working on a sensing device where the voltage of a floating node is dependent on the quantity to be sensed, as well as the net charge stored in the node. I would like the device to be only sensitive to the external physical quantity, and thereby reduce as much as possible the time-variation of charge on the floating node.
In a typical scenario with solid-state memory devices, you would have a MOSFET whose gate is insulated in all directions, and a control gate coupled capacitively to it (and possibly also charging it through tunneling). The floating gate potential induces a certain channel conductance which can be measured with additional circuitry around the MOSFET.
My problem is that the process I am using (TSMC 65nm) has very thin MOSFET gate dielectric, so there is a non-negligible leakage current (on the order of 100 pA) due to electron tunneling across the gate dielectric. The charge stored on the floating node would be on the order of pC so with such currents, the variation will be fairly large and this would provide very low retention.
Are there alternative known ways to measure a floating node potential while drawing as least current as possible from it? One possibility is of course to increase the dielectric thickness of the MOSFET (or its permittivity) but I am constrained with whatever values the process uses.
Maybe you can bootstrap the device so that the voltage across the gate is minimized. I don't recall the function relating current to voltage across a barrier, but I think it's at least exponential.
  • \$\begingroup\$ Yes, there should be a certain voltage where the voltage drop across the barrier becomes close to 0V (so no tunneling). One problem is that the floating node voltage is supposed to vary by +/- 0.1V over the sensing range of operation so there are bound to be cases where I cannot ensure the minimal voltage drop (and as you've mentioned, the current dependence on this voltage drop is at least exponential). \$\endgroup\$
    – Tob Ernack
    Sep 12, 2018 at 21:07
If this is for professional use, use an Electrometer such as this.
This type of meter has an input impedance of 10^14 which is adequate to measure voltage in the leakage environment you have.
There are a huge range of devices spanning low cost to high cost.
You could build an electrometer if you were willing, and here might give you a starting point using an LMC662.
If you are simply DIY experimenting then you can build/buy an electroscope. These are not easily calibrated, but can provide good comparative measurements of charge on a point. You could get something like this for $50 or less.
