Back in the 1970s, Texas Instruments had a now-discontinued range of products that they called GRAM (and read only equivalent GROM) which was basically a standard memory chip with address and data all multiplexed onto 8 pins. You'd start an operation by sending the chip two bytes of address and then every time you pulsed either the read or write pin it would read or write a byte using the bus, then increment the internal address counter. The result was a memory chip that was almost as fast (at least for sequential access operations) as a standard parallel memory chip, but which only need a 16-pin package, rather than the 28-pin packages other similar memories of the day needed.
Today, for similar applications, you'd probably most often use SPI-accessed serial memory -- but the problem is that such memories are quite slow (most have a maximum throughput of about 20Mbit/s; some run as fast as twice that, but I haven't found any faster than that) whereas a modern equivalent of those TI parts could be much faster than that, easily allowing 100+Mbit/s access.
Does anything exist that's still in production and which behaves similarly to those TI chips? The closest I can find today are custom-purpose parts, e.g. the VLSI VS23S010D, which combines a memory device that supports the kind of interface I'm looking for along with a display driver, which puts the pin count up to 48 pins... I'm ideally looking for something in a 14 or 16 pin package (I think 14 is the realistic minimum - 2x power, 8x data, clock, address select, read byte, write byte).
