I have 2 DDR3 x16 chips (MT41K256M16xx) interfaced with an FPGA (M2S150TS-1FCS536). I plan on using point-to-point data & fly-by address/command topologies.
I'm using ECC with a 16 bit bus, so 18 bits total. Because of that, one of the chips is mostly unused. I tried to disable the upper byte by pulling UDM and UDQS high, and UDQS# down with 1k resistors.
How should I connect the unused DQ pins on the partially used byte? How about the unused byte?
