Edit: it is something with the simulate_camera_output
module that Modelsim doesn't like. Tried with a simple test module and it works fine.
Looking for a way to get a Modelsim compilation log.
`timescale 1ps / 1ps
module Cam_tb ;
wire CamSIOD ;
wire CamVSYNC ;
wire HREF ;
wire [7:0] CamD ;
wire CamHREF ;
wire VSYNC ;
wire [23:0] RGB ;
reg CamSIOC ;
reg CamPCLK ;
Cam
DUT (
.CamSIOD (CamSIOD ) ,
.CamVSYNC (CamVSYNC ) ,
.HREF (HREF ) ,
.CamD (CamD ) ,
.CamHREF (CamHREF ) ,
.VSYNC (VSYNC ) ,
.RGB (RGB ) ,
.CamSIOC (CamSIOC ) ,
.CamPCLK (CamPCLK ) );
parameter clock_period = (1000 / 24);
parameter clock_half_period = clock_period / 2;
parameter sim_time = clock_period * 300;
initial
begin
CamPCLK = 1'b0 ;
end
always #(clock_half_period) CamPCLK = ~CamPCLK;
simulate_camera_output sim_cam_out(.CamHREF(CamHREF), .CamVSYNC(CamVSYNC), .CamPCLK(CamPCLK), .CamD(CamD));
initial
begin
#(sim_time) $stop;
end
endmodule
module simulate_camera_output(CamHREF, CamVSYNC, CamPCLK, CamD);
output CamHREF, CamVSYNC, CamPCLK;
output [7:0] CamD;
parameter data_clocks = 16;
parameter h_f_porch = 3;
parameter h_h_sync = 2;
parameter h_b_porch = 5;
parameter h_line_clocks = data_clocks + h_f_porch + h_h_sync + h_b_porch;
integer current_clock = 0;
integer Y1 = 1;
integer Cb = 2;
integer Cr = 3;
integer Y2 = 4;
assign CamHREF = current_clock < data_clocks;
assign CamVSYNC = 0;
assign CamD = (current_clock < data_clocks) ? (current_clock % 4 == 0 ? Cb : (current_clock % 4 == 1 ? Y1 : (current_clock % 4 == 2 ? Cr : Y2))) : 8'bZZZZZZZZ;
always @(posedge CamPCLK)
begin
current_clock = current_clock < h_line_clocks ? current_clock + 1 : 0;
if(current_clock%4 == 0 && CamHREF)
begin
Y1 = Y1 + 10;
Y2 = Y2 + 10;
Cb = Cb + 10;
Cr = Cr + 10;
end
end
endmodule
The main testbench module is Cam_tb
and the second simulate_camera_output
module is in the same file.
I tried "Analyze current file" and it completed successfully.
When I run "RTL Simulation" from Quartus Prime with the simulate_camera_output
module instantiation commented out Modelsim starts up and displays the clock waveform as expected.
When I uncomment the module instantiation and run "RTL Simulation" Modelsim starts up but I end up with all panes blank.
Where should I look to get error messages for what goes wrong in this case?
Or is it just taking long to run? (I don't see any messages about a simulation in progress)
This is what I get in the Messages window in Quartus Prime:
Info (22036): Successfully launched NativeLink simulation (quartus_sh -t "c:/intelfpga_lite/18.0/quartus/common/tcl/internal/nativelink/qnativesim.tcl" --rtl_sim "CamRamVga" "CamRamVga")
Info (22036): For messages from NativeLink execution see the NativeLink log file C:/projects/Camera-RAM-VGA/CamRamVga_nativelink_simulation.rpt
The CamRamVga_nativelink_simulation.rpt
file looks fine.
The code of the DUT Cam module:
module Cam(CamPCLK, CamD, CamHREF, CamVSYNC, CamSIOD, CamSIOC,
RGB, HREF, VSYNC);
input CamPCLK;
input [7:0] CamD;
input CamHREF, CamVSYNC, CamSIOC;
inout CamSIOD;
output [23:0] RGB;
output HREF, VSYNC;
//todo: add appropriate delays for HREF and VSYNC
assign HREF = CamHREF;
assign VSYNC = CamVSYNC;
reg [1:0] InCmpnt = 0;
reg [24:0] InQPar[1:0];
reg [24:0] InQSer[1:0];
reg [23:0] YCbCrPx;
wire InQReady = (InQSer[0][24] == 1);
wire InQCLK = (InCmpnt == 2'd0 || InCmpnt == 2'd2);
always @(posedge CamPCLK && (CamHREF == 0 && !InQReady))
begin
InCmpnt <= 0;
InQPar[0][24:0] <= 0;
InQPar[1][24:0] <= 0;
end
always @(posedge CamPCLK && (CamHREF == 1 || InQReady))
begin
InCmpnt <= InCmpnt + 1;
case(InCmpnt)
2'd0: //Cb
begin
InQPar[0][24] <= CamHREF;
InQPar[0][15:8] <= CamD[7:0];
InQPar[1][15:8] <= CamD[7:0];
InQSer[0][24:0] <= InQPar[0][24:0];
InQSer[1][24:0] <= InQPar[1][24:0];
//todo: XXXXYYYY find a way to re-use code blocks without typing twice (like macros)
end
2'd1: //Y0
begin
InQPar[0][23:16] <= CamD[7:0];
YCbCrPx <= InQSer[0][23:0];
InQSer[0][24:0] <= InQSer[1][24:0];
InQSer[1][24:0] <= 0;
end
2'd2: //Cr
begin
InQPar[1][24] <= CamHREF;
InQPar[0][7:0] <= CamD[7:0];
InQPar[1][7:0] <= CamD[7:0];
end
2'd3: //Y1
begin
InQPar[1][23:16] <= CamD[7:0];
end
default: //Y0
begin
end
endcase
end
endmodule
