I'm using a 0.5 mm pitch FPC connector in my circuit. I was using a DRC with a 4 mil stop mask value. This resulted in a stop mask layer in Eagle (tstop) that looked like the one below:
Based on my understanding that the shaded regions will be areas where no solder mask is applied and concerned that this would lead to potential shorts and difficult in soldering the pins, I manually set the stop areas of the pads to leave more space like below:
Is my understanding of the stop layer correct? If the shaded areas overlap does that mean there would be no insulation applied there?
I know this probably varies between board houses but what thickness of solder mask between pads is ideal to prevent any chances of tearing or defects? I read in a few places that you should leave some overlap of the stop mask over the pads to account for solder mask shifting but I'm concerned that adding any kind of overlap with the 0.5 mm pitch pins would leave only a sliver of solder mask left between the pins.
