For a Coursera test I need to analyze a common source amplifier:
I need to calculate the
- DC gate voltage - easy: -2.3077
- drain current Id - should be easy but the results are wrong. I use this formula from the course or from here: $$ I_d=(\frac{\sqrt{1+4*K*V_1*R_{SS}}-1}{2*\sqrt{K}*R_{SS}})^2 \\ V_1=V_G-V_{TO}-V_{SS} $$
- the drain voltage Vd=Vdd-Id*Rd which gives me -3.7719 V with the "wrong" current ??
- the amplification which gives me -24.8174 (which is wrong!) $$ \frac {V_{out}}{V_{in}}=-\frac {R_D ||R_L}{r_s+R_S||R_3}\\ r_s=\frac{1}{g_m}\\ g_m=2*\sqrt{K*I_D} $$
OK.
Here are my calculations from Matlab:
Vdd=15; Vss=-15;K=1.1*1e-3;Vto=2;R1=150000;R2=110000;Rd=10000;Rs=5000;
R3=200; Rl=10000;
Vg=(Vdd*R2+Vss*R1)/(R1+R2)
Vg = -2.3077
V1=Vg-Vss-Vto
Id=((sqrt(1+4*K*V1*Rs)-1)/(2*Rs*sqrt(K)))^2
Id=0.0019
Vd=Vdd-Id*Rd
Vd = -3.7719
gm=2*sqrt(K+Id)
rs=1/gm
gac=-R_parallel(Rd, Rl)/(rs+R_parallel(Rs, R3))
gac = -24.8174
No I wonder am I too dumb to be true or is there a flaw in the automatic grader?
In case I am too dumb, please, tell, where my error is. Thanks.
