What I was wondering is it is possible to use a single voltage multiplier to provide a negative and positive voltage. Referring to this voltage doubler circuit, if you connect a capacitor to the top right node, and an ac source to that capacitor, can it produce dc voltage with the reverse polarity? I think it looks like it would because the diodes would be in the opposite polarity relative to the capacitor.
  • \$\begingroup\$ Recognize that adding a "-Vout" multiplier to a "+Vout" multiplier will load the AC source - requiring more current (to charge all those capacitors, and to provide DC current to any load on +Vout, -Vout). The extra load may reduce the magnitude of Vout somewhat. \$\endgroup\$
    – glen_geek
    Commented Sep 18, 2018 at 17:00
If you mean this: -
Then yes but you'll still need another set of diodes and capacitors to keep your positive voltage. If this is not what you meant then I suggest you draw a picture of what you mean.
