Can we use zinc plated screws for PCB grounding? Means the zinc coated screw head will be in contact with copper trace on PCB for grounding. But this can cause galvanic corrosion between zinc and copper. Can you all advise me on this topic? Can this cause galvanic corrosion?
    \$\begingroup\$ Would the copper track not normally have something over it? Such as HASL or ENIG finish? Also, what current (if any) do you expect to flow through the screw, and which way? \$\endgroup\$ – Jack B Sep 20 '18 at 12:15
    \$\begingroup\$ Why would the screw touch copper? Wouldn't it touch the finished PCB surface? \$\endgroup\$ – Olin Lathrop Sep 20 '18 at 12:16
  • 7
    \$\begingroup\$ Last time I did that, we were required to use star washer in between to guarantee it would bite though the playing and into the copper. \$\endgroup\$ – winny Sep 20 '18 at 12:20
  • \$\begingroup\$ Jack B : Yes the copper layer will have an OSP layer \$\endgroup\$ – Sumit Sep 20 '18 at 12:22
  • \$\begingroup\$ If super-concerned about it, assemble with dielectric grease. \$\endgroup\$ – rdtsc Sep 20 '18 at 14:44
If you can't tolerate corrosion then don't use zinc on copper. If you look on the table below zinc on copper is ADE which means plating is consumed and corrosion increased. Another thing to consider is if the copper is plated then it will be zinc on nickel but I don't have info on that.
enter image description here Source: http://www.preservationscience.com/materials/metals/PGC.html
|improve this answer|||||
You also have the option of printing solder paste over the OSP and reflow. I'm not recommending it, but I believe that's common with motherboards, for example. The main reason in that case would be for EMI mitigation, and perhaps nobody has checked motherboards for compliance after a few years.
Any connection that's not gas-tight has potential problems. If you really need a solid earth connection (for example, for safety) you may have to solder or stake a connector in.
