6
What do these arrows represent? Is there any way to memorize it easily?
    \$\begingroup\$ Out of interest, why would you need to memorise them? \$\endgroup\$ – Steve Melnikoff Sep 22 '18 at 13:44
    \$\begingroup\$ This is precisely what these arrows are here for: to designate signal directions, so you don't need to "memorize" the major pin function. \$\endgroup\$ – Ale..chenski Sep 22 '18 at 16:45
  • \$\begingroup\$ @SteveMelnikoff i have a test on microprocessors . i have to draw pin config and architecture of various processors . \$\endgroup\$ – Mark Henry Sep 23 '18 at 5:36
  • \$\begingroup\$ Argh; I used to hate stuff like that. The good news is that, in the real world, you can refer to datasheets as often as you like. :-) \$\endgroup\$ – Steve Melnikoff Sep 27 '18 at 11:25
16
They indicate data direction. Arrows pointing to the chip indicate that those pins are inputs and vice versa. Bidirectional arrows indicate they are either inputs/outputs, depending on the circumstances.
If you want to memorize it, I think you should memorize those pins meanings first.
| improve this answer | |
  • \$\begingroup\$ yea i have memorized the pins , the problem is that some pins have 2 arrows and some dont . \$\endgroup\$ – Mark Henry Sep 22 '18 at 4:16
    \$\begingroup\$ @MarkHenry The double arrows represent pins that are bidirectional - may be either input or output, depending on the circumstances. \$\endgroup\$ – DoxyLover Sep 22 '18 at 5:20
