I know there is a difference between modeling BJT and JFET devices for small signals, but I would really like to know, in depth, how to explain this difference.
  • \$\begingroup\$ Are you talking about the fact that a BJT is fundamentally a current-controlled current source while a FET is a voltage-controlled current source? Or something more subtle than that? \$\endgroup\$ – Dave Tweed Sep 7 '12 at 16:16
The form of the small-signal models for the BJT/FET are essentially the same. This is because of the way small-signal models are constructed.
In both cases, there is an equation that relates the collector/drain current to base-emitter/gate-source voltage and the collector-emitter/drain-source voltage.
To derive the small-signal model, the collector/drain current equations are Taylor expanded about the operating point and only the first order (linear) terms are kept (thus the small-signal approximation).
The term involving the base-emitter/gate-source voltage is modelled as a voltage controlled current source. The term involving the collector-emitter/drain-source voltage is modelled as a resistor.
In the case of the BJT, we do something similar with the base current equation and model the linear term there with a resistor. Since the (DC) gate current is zero, there is no equivalent resistor in the model.
Of course, this simple picture ignores the inter-element capacitance and other departures from the basic governing equations.
A nice derivation of the BJT small-signal model is here. The FET version is here.
A fet is a voltage controlled current source and a BJT is a current controlled current source.
    \$\begingroup\$ He wants to know about small signal behaviour. \$\endgroup\$ – Federico Russo Sep 7 '12 at 18:52
